Some people here need to get a grip. The act of doing a roll or flip is not in and of itself going to cause the airframe to break up, unless you do the maneuver all wrong.
The problem with that line of thought is that it is very easy to do a "simple" barrel roll wrong. Wrong to the point where it takes an over-G to recover from the post-maneuver dive that resulted from the improper maneuver. It is a common student error to end up in a dive after an improper roll...VERY common.
How much experience do you have teaching aerobatics?
By the way...what is a 'flip' and how is it done with 'minor G forces'?
In my experience, you don't have to be a Bob Hoover in order to be able to do a barrel roll every time with some certainty of not messing it up.
You also need not be named Hoover to know the CFR well enough to be aware that the maneuver(s) in question are not legal.
We've all ready established that it CAN be done. The question is, SHOULD it be done. This is where the previously mentioned concept of "flight discipline" comes into play -- knowing the rules inside and out, and making informed decisions about how to operate your craft with that knowledge in mind.
Flight discipline is the cornerstone to being a pilot.
The idea that someone would know that it's not legal to perform an aerobatic maneuver in a particular aircraft, and then go perform that maneuver anyway is a blatant violation of flight discipline. It takes an action that could be considered a 'mistake' if the pilot did not have knowledge that it was wrong, and turns that action into a 'crime'.
And another thing. If a plane is damaged to the point where the airframe will likely breakup when the next renter tries turns around a point, there is going to be some kind of external indication of the damages. If a pilot tries to fly a plane with crinkled skin or a bent wing, can you really fell sorry for them if they crashed?
No, sorry, not true.
How much experience do you have with airplanes that are ovrstressed? Overstressed and fatigued metal does NOT always bend prior to breaking. This is why there are processes like NDI, magnafluxing, electrical eddy current, dye penetrant, etc, which are able to detect cracked and stressed metal that is not visible to the eye.
