ZapBrannigan
If it ain’t a Boeing, I’m not going. No choice.
Boeing withdrew their request to certify the Max -7 (and Max -10) without changes to the anti-ice system.
For those who are unaware, the 737 doesn’t have an ice detector or automatic cowl anti-ice. It relies on the crew to turn on and off the cowl anti ice in icing conditions. On the NG, if you forget to turn it off for a while it’s no big deal. On the Max, apparently there is a very slim chance that if you operate it in dry air at a very specific combination of temperature, altitude, phase of the moon etc.… the cowl lip might get too hot, come apart, puncture the fuselage and whatnot.
Boeing wanted to certify the Max -7 anyway based on millions of hours flown with the -8 with no issues, while they work on a fix which they said would take several years.
After the Alaska incident several congress critters said “no more exemptions!”. They already gave Boeing a get out of jail free card on EICAS for the -7 and -10. They’re mad about loose rudder bolts and apparently missing door bolts. So Boeing rescinded their request.
That means waiting for a fix which is likely to add several years to the -7 timeline. Which is no big deal unless you need to replace an aging fleet of hundreds of -700s…
Airbus has no capacity for additional lines to fill that demand. Even if they did they’re dealing with their own P&W GTF issues and apparently an EASA mandate to check for spar cracks.
Embraer doesn’t have anything that can carry 150 pax with the range the -7 promised.
This is bad.
