NJA_Capt
http://www.youtube.com/watch?v=iTFZNrTYp3k&feature=player_embedded
Still want that Comanche job?![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
PS....This is what I got my multi in.
This 23 second video clip shows the PA-30 Twin Comanche during a tail flutter test
After being purchased in 1967, NASA 808 was used as a testbed for general aviation flight control research. NASA's first project with the aircraft was the determination of its stability and control characteristics in the Langley full-scale wind tunnel. The wind tunnel measurements were then correlated with in-flight measurements of the stability and control characteristics at Dryden. This was the first time full-scale wind tunnel measurements of a general aviation aircraft had been made since the late 1930s. As a result of the studies, several changes were made by the contractor to the aircraft to improve its flying qualities. These changes are manifested in later models of the airplane.
is there anything one can do once they notice this fluttering happening?
I don't remember exactly, but it was beyond VNE.How fast were they going?
There is another (I can't find) that has the PA28 spin tests. They gradually add weight to the tail until the spin goes flat and the pilot jettisons the weight and reaches for the door jettison handle when it starts to recover.
On a similar note, apparently Beech did full-on spin testing of a Baron a few years back. There were a few modes (most of them with differential power, IIRC) that resulted in spins that required a chute to recover.We had an examiner that claims he rode along during a full Vmc of a light twin with a spin chute from NASA.
Coming fall 2010, the Twin Cirrus....On a similar note, apparently Beech did full-on spin testing of a Baron a few years back. There were a few modes (most of them with differential power, IIRC) that resulted in spins that required a chute to recover.
