Cptnchia
Dissatisfied Customer
I thought NovemberEcho and plenty of others had made it abundantly clear that you don't fly into something you don't like. That's not a question here, and shouldn't ever be. I fly in NY airspace multiple times daily. I fly entire legs under NY TRACON control (EWR-BDL, EWR-AVP). In seven years of doing that, I've had maybe two instances where those guys wanted to put me somewhere where I didn't want to be. Both times, we worked as a team to find a better route. I get frustrated with guys who don't see the big picture, want to go somewhere they can't, and then get mouthy on frequency about it. I think someone earlier mentioned that with TCAS we'd be fine. Wow. Sure, you may not have a mid air, but give an entire congo line an RA, and see how that works. Or, worse yet, blunder into a stack up over a hold. Often, when there's weather, these guys have a very narrow window to work your flight in. They take what you say seriously. If you say, "hey, that routing is not going to work" they are going to close that route down for the numerous aircraft in line behind you. If that's the last route into the airspace, guess what, the airspace is closed. Then comes the groundstop, and horrendous EDCTs. Now, if the weather has moved across the fix, so be it. But, if the controller is telling you that the routing is working, it might be worth a closer look. Basically, I'm saying that there's no room in the cockpit, or on frequency for an ego. Yes, NovemberEcho could have worded his IP a little better, but DON'T develop an ego around the fact that you are in charge of the airplane.
Well, there you have it. @Hammertime has dropped the hammer. Disregard at your peril you know nothing hacks!
