SlumTodd_Millionaire
Most Hated Member
I trust ALPA's safety department far more than any company manual. ALPA is far more conservative.
Of course you can always ignore ALPAs advice like these guys did:
For sure ALPA not a perfect organization
But this is one thing that those who know about the history of TCAS are thankful for ALPAs involvement.
And as for the ALPA advice, it actually benefits every pilot even you.
I'm guessing you don't have TCAS II though....
Cheers
George
Actually kind of a pet peeve of mine when another pilot says it, but without visually spotting the traffic, what in the world does "I've got him on TCAS" do for the controller, if anything?
What's TCAS II? I have no idea what that is.
The GP allows military pilots to provide their own separation from traffic while operating under due regard. Perhaps these pilots just need some explaining that while under contol they aren't due regard?Even better are the F15 pilots at my base that report the traffic on their air to air radar and want to follow it to the airport with it :banghead: so frustrating trying to get them to call visual since radar contact from the pilot means nothing.
stuckingfk said:Just wondering why you have you bring ALPA into the convo when there are many things published that a pilot should read before listening to the holy union.
I believe it is the system that uses Mode S for deconflicting altitudes rather than Mode C.
I didn't think a sarcasm tag was needed, guess I was wrong.
If you look at my previous posts you'll understand.
Not hating at all. Just wondering why you have you bring ALPA into the convo
I went mildy balistic a few weeks ago when my FO said 'they had the traffic on the fish finder.'
That's because we do an immense amount of air-air work with the radar and are very comfortable using it as a primary means of situational awareness on aircraft that are out of our visual range.
We also follow each other around through the weather ("ducks in a row") using only the radar as our means of separation.
So, while I understand your frustration, it's a very natural request from someone who is very comfortable with and used to using a radar for traffic separation.
ALPA's involvement in TCAS development has been extensive. They are probably the best source available to pilots on TCAS information.
TCAS II is what's in the airplanes that you fly. TCAS I is a rudimentary version which doesn't offer RAs, only TAs. TCAS III was to be the next generation of TCAS which would have added horizontal RAs to the present vertical RAs. i.e. "Turn Right, Climb". TCAS III is no longer in development.
BTW, Google is your friend... http://en.wikipedia.org/wiki/TCAS
Back to the topic of the thread...
Per the pilot/controller glossary, there are two responses to a traffic point out from ATC, "Traffic in sight" or "Negative contact". If you have more to say then include it along with the appropriate response. i.e. "Negative contact, request vectors to join the ILS." Don't tell ATC about TCAS unless it fails or you are responding to an RA. Doing so serves no purpose.
If I get an RA, I'm following the RA guidance whether I think I see the traffic or not. I might be looking at the wrong traffic without realizing it, for all I know. The ALPA safety department makes a very big deal out of this. Never ignore RA guidance!
I hope you would not do this in a busy terminal environment. If you respond to an RA around Atlanta chances are you are going to create more collision hazards than you have resolved.
Chris
TCAS I on crack cocaine! I really don't know.....more pretty colors and instead of a female voice a sean connery voice
