CaptBill
Here is an easy way to determine if you need to check in. If you are traveling on some kind of pass - ID 90, Company travel benefits or any kind of a pass, you DO NOT have to check with the captain. If you are using a jumpseat request to board the aircraft, even if you have been assigned a seat in the back, you DO need to check in up front. "Good morning captain, my name is Jeff and I'm with ABC airlines... Can I talk you out of a ride home today? .... The agent assigned me a seat in the back if that's OK?" Have your ID, license and medical handy if he or she wants to see it.
The concept here is not where you sit, it's the method you use to obtain a seat. If you filled out a jumpseat request to gain access to the aircraft, you need to check in up front regardless of where you sit. DO NOT go by what the gate agent says....
Not every captain would take issue with you going to the back without checking in, but plenty would, including me. It's also a courtesy and an opportunity to express your appreciation for your ride home. I always do it, always have and always will.
Also, don't make the mistake of thinking that a captain on a 1900 deserves any less courtesy than a 747 captain. Be humble, be friendly and err on the side of always having a face to face with the captain. Your commuting life will be easier for your efforts.
