Thanks for the *cough cough* simple explanation. ha!
Yeah well... I tried. :> But...
No, but this sentence is really what I was curious about. In straight-and-level upright flight at a certain speed and weight, let's say you require 2 degrees of AoA. Thankfully, our engineers designed that into the angle of incidence of the wing. We fly level, no stick input.
TwoTwoLeft - You were right. ;>
Upside down at the exact same speed and weight, just by me having to put in that forward control on the stick, it's telling me that I am eating into that buffer.
You're probably eating into your buffer, but
not because you're putting in forward stick. Now we're getting into the control of the aircraft. Angle of incidence is mostly important from a meat cargo and thrust alignment point of view, and from a 'rational aircraft' point of view. It has no bearing on AoA.
When you roll inverted and push, you're merely assuming a similar (symmetrical airfoil) or equivalent (asymmetrical airfoil) AoA for level flight. In an asymmetrical airfoil, you're losing efficiency inverted due to the camber, and thus you DO eat more into your AoA buffer to maintain lift.
This is where, as 22L had pointed out earlier, the horizontal stabilizer and elevator design becomes important in the practical aspects of realistic airplane design. But again, we're overcomplicating things a bit.
So, another thought experiment: A
completely symmetrical flying wing. Fly it level. Fly it inverted. Does it care?
In other words, I need a higher angle of attack while upside down vs. right-side-up to maintain level flight with all other variables being the same.
Would you, given a completely symmetrical flying wing?
(You wouldn't, so what are the extra variables here?)
So I guess all other variables being the same, flying upside down gives you a much smaller envelope.
Again, not necessarily. For a symmetrical wing, AoA is AoA, and it really doesn't care.
It may produce more drag at an equivalent AoA because the rest of the airplane is designed to fly upright, or you may run out of authority on some other control surface for the same reason. For an
asymmetrical wing, you need a bit more negative AoA than positive AoA to offset the camber of the airfoil.
*Pant*
~Fox
IANAAS IANAA IANAP IANACG IANAL IANEAGF WTFDIK YMMV SRA NWEEOI
