So my curious and innocent question is...with an airplane upside down, is the "lift" going towards the earth or away? And is the majority of lift then created by the wing or by the elevator?
Wait, you're a pi... aw, just kidding.
Bear with me for a little stupid thought-experiment here:
Assume we have an atmosphere but no gravity. If you take a baseball and release it at eye level it will stay there. If you push it, it will move forward for a bit, but eventually stop. We're in a giant box, fifty miles to a side.
The amount of lift you need to produce to stay aloft is... well, zero. But if you point your nose at a target straight across the box, you'd be generating lift as you pass through the air, so you would be gaining altitude as you went along. Why are y0u gaining altitude? You're producing lift. Why are you producing lift? Because the design of the airfoil (most airfoils) and/or the angle the airfoil is mounted to the aircraft result in a positive angle of attack or accelerate airflow sufficient to produce some lift. To stop this altitude gain, you could either stop moving forward through the air,
or you could decrease the angle of attack through zero until you found a point where you no longer gained altitude flying straight ahead. That angle of attack is the attitude you could fly to get from one side of the box to the other. Less than that, and you 'lose' altitude. More than that, you gain altitude. Accelerate, and you produce more lift for a given angle of attack; decelerate, and you produce less.
To fly a 'straight course' to the other side of the box, you want zero lift... but you can think of that as 'zero pounds' of lift.
But hey, since we're in a giant box, fifty miles to a side, why not just point straight down and find that point again where we're no longer going up or down? The attitude in which we produce zero pounds of lift? And then push the nose forward to go back the way we came?
And why straight sideways, straight up, or straight down? If we "decrease" our angle of attack, we will go "downward" relative to our aircraft. If we increase it, we will go "upward", again, relative to our aircraft. It doesn't matter. You could have runways facing any direction and land on them as easy as you please.
Now the -only- confounding factor that we have on this planet that makes it different from that little experiment is gravity. If you're flying upright and you weigh 2240lbs, you need to be producing 2240lbs of lift to not descend.
Now, take the same airplane and flip it over. How much lift do you need to produce to stay aloft? at least 2240lbs. That's all gravity does for you that changes anything.
Symmetrical or asymmetrical airfoil, doesn't matter. An asymmetrical airfoil will be less efficient generating 'negative lift', because its shape produces some lift by itself independent of AoA, but effectively you change the amount of lift produced by changing speed and AoA. A symmetrical wing is producing zero pounds of lift at 0° AoA.
Flip the plane over, and what do you have to do to maintain level flight? You have to increase angle of attack... in a negative direction. By pushing forward on the stick.
So what if you need to produce more lift? What if you slow down? What happens to lift? 2240lbs to remain aloft, but your speed is decreasing, so you have to ____________ your angle of attack by pushing __________ on the stick?
And what happens when you exceed your critical angle of attack?
Going back to my gravity-less box, what happens when you stall there? What's the only dfference between 'there' and 'the real world'?
I guess what I am asking is...in the most simple of explanations, when an airplane is flying upside down and stalls, does it momentarily pitch up (from someone standing on the ground) due to the airflow separation and then fall down with gravity, or does gravity just grab that whole bird and drag her down once the critical angle of attack is hit?
I hope my stupid, long-winded thing has helped, and that you've been able to answer that question for yourself at this point. But if not: If you stall inverted, the nose drops. Towards the earth. Because of gravity. Because you've exceeded the critical angle of attack pushing forward on the stick.
Hopefully that wasn't condescending, too simple, too complicated, too short or too long... but I'm sure it managed to be all of those. I'll have to work out a better explanation.
~Fox
