That's the way I do the NTS check and I do it every leg. If I get the RPM's up high enough, I know I didn't get a prop off the lock. I've done this before too. A lot less embarrassing then an aborted takeoff or a go/stop/go takeoff
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. A NTS failure on a hot/heavy takeoff with a V1 cut, I would say your chance of surviving it is about 5%. In the sim you know it's coming, so you're ready for it, on the line you get one, after the o-crap moment, it's already to late, you're just dead. Same with a V1 cut w/ a left essential bus failure or a V1 cut with the gear solenoid lock failing. Moral of the story, if you're going to skip every preflight inspection besides one, make sure you do a NTS check.
