CoffeeIcePapers
Well-Hung Member
Since I am joining the ranks of the OOTSK, give me some pointers. I start class on the 4th.
Accept right now that it's not a beechcraft, and all will be well.
No really, once you embrace certain oddities(which aren't really that odd), it really is just another airplane. I got used to it at about 40 hours. About the same amount of time in the 99 actually.
My only pointer is that corrections require more input than you think. The controls are pretty heavy. Hopefully it's not on your checkride, but request that your sim instructor gives you a V1 cut with losing the left essential bus. Not likely to happen, but it's good to see. Short of a lion getting loose in the back, that is one of the worst, if not the worst thing that can happen to you in this plane.
Also, go ahead and use the rudder if you run out of aileron authority in turbulence, on final for example.
I'll let the more experienced guys comment further.
Who are you working for?
Reaching behind you to transfer power for the he gear to the right bus. Oh yeah, you lose your flight instruments too. Super!What happens that's so bad when that happens?
If the fire goes out, not at all. I guess if it was because of a bleed, and you were in icing, that could suck as you would be going single engine. If it doesn't you need to get the thing down. I don't recall how long that Canadian crew flew around with the gear well on fire before they lost the wing. The previous scenario require INSTANT action or you don't climb, and I be properly impressed with someone keeping the dirty side down partial panel at that particular moment while reaching behind them to transfer powerIsn't the wing overheat like the worst thing that can happen if it's for real? Like it's basically a wing is about to fall off annunciator?
What, freight hounds aren't smart???Hallelujah! And in the freight dog section no less.
Always expect the nosewheel steering to fail at any moment and you'll be golden.
Pretty much. Two things to help prevent/alleviate an incident with it OP.No worries with losing the left essential bus with a left engine failure...all of our planes have been modified to the 'new' standard where the essentials are tied. Left engine failure is now as easy as a right engine failure.
I did one in the sim with the old configuration...how they ever got it certified like that is beyond me.
Enjoy flying one of the few planes that still regularly burns alcohol on takeoff. Do not enjoy the sudden, dramatic, and depressing loss of power when you turn the alcohol off.
With middle fingers instead of the index fingers too!Make sure to let the whole world know you fly a Metroliner, too. And expect the Garrett Salute.![]()
Some do, some don't. Probably just didn't feel like painting it white. HahaSo why do Ameriflight Metros have a black nose?
