Bumblebee
Commodore
is it an emergency if a motor glider's engine fails at 10,000'?A Cessna will glide 10:1
A motor glider will glide 20:1
They are both gliding. It's just energy management.
A motorglider is designed to be flown as a glider.
A Cessna is not designed to be flown as a glider...Other than a 10:1 vs a 20:1 ratio, I see no difference between a a Cessna with the engine off and the motorglider with the engine off. Same physics, same controls, same options.
and I used to go from Cal Expo into SAC with the engine pulled back too to practice...just never would shut off the engine.
what's that for? best glide in an emergency!
I hate trees, nature, and kittens.Gas waster!
Club some baby seals while you're at it next time![]()
...not hey let's shut off the engine on purpose.
OK, I have to get moving...this will be fun to read aloud at NJC![]()
All systems aren't functioning when the big fan out front is purposefully turned off.
When teaching engine failures, my first point of briefing is that the Cessna is a perfectly good glider.That's my point. You comparing a glider landing to a Cessna with the engine purposefully shut off is apples to potatoes.
Flight training is a high risk environment. Yes, we all understand that pulling the mixture in flight is an added risk and it should only be undertaken in an environment that offsets this risk.I'm not emotional, I'm just at a loss as to why you think it's ok to put yourself and a student in a high risk environment unnecessarily.
You could ask for the engine to keep working!Can't ask for more than that!! Well, I guess you, "Could" ask for more.....
Glad these guys didn't have to ride the ambulance today!
