ppragman
FLIPY FLAPS!
Lower than standard takeoff mins will do it too if memory serves.Ah yeah, that would do it. I’ve only done single pilot so I forget that EOD is a thing and what it can do.
Ah yeah, that would do it. I’ve only done single pilot so I forget that EOD is a thing and what it can do.Eligible on-demand with an SIC that meets the requirements?
Sent from my iPad using Tapatalk Pro
Right, but the presupposition from the OP was that after checking all the boxes and doing the flow chart he still needed 1 SM to blast off.Lower than standard takeoff mins will do it too if memory serves.
no...it’s I need a mile, I can see I have a mile, but the legally required weather station says I don’t. Is there a way to launch short of checking the ramp for FAA/CP types and going all leeeeroyyy jeeeeenkins?“I need 1sm to takeoff. What visibility do I need to takeoff with?”
Is that the question?
Yup. EOD means you can get in, but you can't get out.EOD only gives the crew the option to shoot an approach without weather reporting and land if they have the flight vis. Doesn’t say anything about taking off.
Don’t look at me....an FAA lawyer wrote that junk.
Yes. Need a mile. Looking down the runway, it’s obviously over that. ( but NOT vfr), and awos is stuck on 1/2 or 3/4....Right, but the presupposition from the OP was that after checking all the boxes and doing the flow chart he still needed 1 SM to blast off.
Cancel release. Depart VFR.You’ve lined up on the 7000 ft runway and can see the tree line past the other end of the runway at an uncontrolled field. AWOS is calling it a 1/2 mile.
What to do......what to do.....?
The FSDO nor a POI can wave a regulation or reinterpret a interpretation. It's literally irrelevant what their opinion on the matter is when the lawyers get involved for whatever reason.1. The FAA’s position is that the AWOS is controlling for the entire field, even if conditions vary on the field. As far as the FAA is concerned, if the AWOS says it’s less than a mile, it’s less than a mile, despite the fact that you can see more than a mile. The legal department has issued a letter on this and if I can find my copy I’ll update this post with the details.
2. AWOS devices use an averaging function when determining visibility. When visibility is improving it is common for the AWOS to lag by about 15 minutes. Sometimes all you need to do is wait a little bit to be legal.
3. Some locations have poorly located weather facilities that produce erroneous readings. Point Hope (PAPO) is a good example: structures near the weather station cause blowing snow to swirl around the visibility sensors. It is not uncommon for its AWOS to be reporting low vis while the cameras show good vis. Depending on your company’s relationship with the FSDO, it may be OK to dispatch to or from such a location; we would do it at the handful of known problem airports because we had systems that could prove to the FSDO that conditions really were better than what the AWOS was reporting. I’d guess that the vast majority of pilots aren’t in and out of the same uncontrolled field on a regular basis, so it’s likely that few are in a position to work out an understanding with the FSDO, but I bring it up because @ppragman, @Capt. Chaos, @Roger Roger and a few others here probably have faced similar circumstances.
4. Any time you find yourself operating at a field where the AWOS and your eyeballs disagree you should report it to the FSDO and ATC. FSDOs do keep track of problem areas and can help get problem areas fixed.
Great question. In this scenario lets say it’s 300 obscured in mist. Remaining clear of clouds would be problematic.How is it not VFR if it’s daytime, class G at the surface?
Agreed. We showed the FSDO and our POI that the AWOS was giving bum readings by having them look at the camera and the AWOS simultaneously. There were no repercussions when we continued to go into those airports while the AWOS was reporting low vis. There wasn’t a waiver or reinterpretation, and there weren’t any issues. Like in a lot of situations in Alaska, common sense prevailed.The FSDO nor a POI can wave a regulation or reinterpret a interpretation. It's literally irrelevant what their opinion on the matter is when the lawyers get involved for whatever reason.
If I needed an official observation and it was showing 1/2 mile, but I think I could see a mile, I'd be in the FBO watching Jerry Springer.
There's no "on time, on target, or Americans DIE" in the commercial aviation business.
