I feel like this will be (probably already is) an interview question...
You're the the captain. FO is all over the place on final/short final, what do you do?
Answer: Anthing but this
Go around.
Without question I agree. Fixed it.Go around.
Go around.
For sure. Never heard of anyone losing a job for a go around. And, if I'm not mistaken, we get paid by the minute.
FLCH is largely "speed on pitch" for the most part. You want to climb/descend, it's full/idle thrust and the nose will pitch to maintain speed. Some airplanes have a "program" of sorts where it's a blend of "speed on pitch" rounding out the aggressiveness.
Personally, at the risk of the Boeing and Douglas guys whipping my ass, I kiiiiiiiinda enjoy FPA (Flight Path Angle).
I use the birdwing on the 717 any time I'm flying a non straight in visual approach. I think I'm the only person that does it though as most captains look at me like I'm crazy.
IMO, on Fifi the FPA "bird" is nothing but a distraction. I don't need a plane symbol on the attitude indicator to show me what the plane is doing. I'm looking outside at the runway, the PAPI, and inside at the airspeed. The only time our Co. requires FPA/bird usage is in the localizer approach on descent from the FAF to the MDA+50'.
VS, in the most simple terms is a mode in which vertical speed is the utmost priority. It works well, is smooth and in many cases preferable, but will whip your black ass (sorry, I can only write in terms which I can relate with) if you use it incorrectly. If you command a 3000 fpm climb, it'll pitch for that and disregard airspeed. A mad dog in VS mode will gladly stall you in a climb or drive you through the red line in a descent. If you command a slight climb, the autothrust will edge forward a little to maintain speed and the reverse in a descent. BUT, you sure better be confident in what you're asking it to do.
We're largely arguing "technique" but on the internet, thanks to the way we roll politically, it's "A or B". I'm an "moderate" which means that I see the value AND the danger in both extremes.
The big thing to remember is that autopilots are awesome! at doing exactly what you commanded it, right or wrong
AMARITE, @PeanuckleCRJ?
I fixed it for ya.JetBlue was extremely forward thinking with their dual HUD installation. It's unsurprising that more operators were unwilling to spend the money to be that progressive.
Fifi= AirbusWhat is Fifi, and FPA?
That's because all of the approaches you shoot (with maybe the exception of the Canarsie into JFK) are straight in and you have a runway and PAPI to look at.
I've never flown the Airbus, so I can't comment on its usefulness there, but on the E-Jet PFD you can't even deselect the FPV. Once you select a vertical mode after takeoff, it's there for good. The FD is even flight path based. It was explained to me by an Embraer test pilot that they designed it that way because they thought for sure that everyone would order the airplane with dual-HUD's, so they wanted the symbology to match on both the PFD and the HUD.
When you really think about it, a lot of the pitch/power flying we do is all in the effort to maintain a constant FPA. So it makes sense to me to have an indication of that on the PFD, and further to have a way to set FPA. Of course, FPA doesn't exactly fit every scenario, but in certain maneuvers, it is an incredibly useful tool.
I'm waiting to debate the effects of Various modes on the DC8 vs a CRJ.
