Yes. You need to add it up I am afraid. Makes a good argument for electronic logbooks![]()
The NDB in Show Low sucks.
I actually have Logbook Pro. I was unaware that I could get it to add up point to point flights...
I've never had an issue with arcs. Done one or two in actual. Dunno, maybe trying it in the Navajo will scramble my brains....
It's interesting to see Amflight's relatively slow/late embrace of the GPS. Seems affordable enough these days and you can't put a price on that kind of SA, not to mention the theoretical fuels savings of going direct when it's available.
If you're uncomfortable flying without a GPS, you will very likely be umcomfortable at amflight for a very long time. Nearly four years after I left, they haven't gone too far with it, and I doubt things will speed up anytime soon.
You can't even really say that it makes pilots navigationally complacent because, in order to successfully use it in IMC, it requires training and just as much IFR ability [from the pilot] as navigating with 2 VORs and a DME. Only difference is, the GPS leaves far less gray area as to where you actually are in space. And there ain't nothing wrong with that.
I'm not uncomfortable without it, I was merely questioning the logic behind not incorporating it as means of improving safety/SA and to a lesser extent, efficiency.
This is sort of where there's a lame dichotomy among certain groups of pilots: the GPS-is-for-pilots-who-aren't-real-pilots camp and the pilots who just enjoy having as much positional accuracy as possible. I'll navigate with 2 VORs all day long, but I'm not going to poo-poo the GPS as some crutch for the navigationally challenged. It's a damn good tool, and makes more airports more usable in IFR conditions. And they're getting better and more affordable everyday.
Really, what argument is there against GPS anymore? Too many database updates required? You can't even really say that it makes pilots navigationally complacent because, in order to successfully use it in IMC, it requires training and just as much IFR ability [from the pilot] as navigating with 2 VORs and a DME. Only difference is, the GPS leaves far less gray area as to where you actually are in space. And there ain't nothing wrong with that.
Sorry, for the rant there. Like I said, I'll fly IFR with whatever equipment they give me; but I won't play the I'm a Better Pilot than You Because I Don't Need GPS game.
Just my 2 cents.
DME?! What kind of nancy crutch equipment is that?! Real pilots navigate with VOR's and a watch. :rotfl:
As to better situational awareness, I agree that GPS is great for that, but to say that it somehow increases safety is rather amusing. While it does make things easier, a proficient IFR pilot is not going to run into a hill or mountain following a NDB/VOR/LORAN/INS/AN RANGE or any other type of navaid. When you run into the mountain or hill is because you aren't following the procedures correctly, and the GPS can't fix stupid.
VOR's pshaw
lighted airway is where it's at.
I make it a point to always carry a cat with me.
The last NDB approach I shot was into Winnipeg Manitoba. There is also a airway out of Miami that uses an NDB that we fly daily. You will have to get comfortable with flying without a GPS unit. All of the aircraft have HSI's and DME's with the exception of a few navajos. I agree with flyboy. A gps unit does not make you anymore of a safe of efficient pilot. Knowing the equipment and resources that you have, knowing their limitations, and being able to use them to it's full extent is the key.
If you look at skyvector you will see dark brown NDB routes in south Florida. Mainly because of the islands.
cool, I do remember the routes in the Keys now. Were I fly (Islands Nation) the only routes are NDB.
