Three hours is not enough time to change a ground spoiler actuator on a G-IV. You have to remove the flap for access and if you're doing it properly you'd run a flap symmetry check after reinstallation. Not to mention verifying spoiler angles before you start and reverifying them afterwards. It's been a while since I've done a T/O Alarm check on a G-IV but I think it relies on the ground spoiler arm/off switch selection, speed brake lever position and either throttle lever angle. The "rear beam" on the wing of a G-IV is a pretty busy area, ground and flight spoiler actuators and their bellcranks, pushrods and hydraulic lines, not to mention aileron actuators and their control cables, plus the flap actuators and their driveshafts. "IF" you're doing it right you have to verify all of the systems you disturbed are functionally tested and are operating properly. You'd need a GPU, a hydraulic mule (unless you want to run the engines for hydraulic power, but the report says they took it to a hangar), a calibrated tensiometer, a protractor and a flap test box. Whoever signed it off probably hasn't slept well in a while. Maybe someone will buy him a fan.
