JustinA
I have a little info on The emergency gyro switch that I somehow just remembered. If you lose your battery, This switch will turn on the flood light and attitude indicator. It does this by D cell batteries hooked it up to it. If I remember correctly, It will for last either 30 or 45 minutes. Go with 30, just to be sure.
If you need to come here to learn about it, i dont think you should teach others to fly it.
But, heres some answers
The E or Essential Buss will give you the annunciator panel, batterey, essential avionics-bus (com1 nav1 gps1 xpdr) bus interconnection, flaps, flood lights, art. horizon, engine instruments, landing lights, master control (av master, ess bus switch, ess avionics relay, bus interconnection relay, av master relay) and pitot heat
The emergency gyro switch gives you the flood lights and artificial horizon in an emergency that would call for you to turn the master switch off.
and the altimeter, artificial horizon, and airspeed indicators are backups if the G1000 were to fail.
Hope this helps, but again, maybe you should get better aquainted with the airplane before teaching someone.
