R
Roger, Roger
Guest
Does he know what to do if the AHRS pukes its cookies?
Actually, we should be clear on two different times for the emergency backup power. The essential bus lasts up to 30 mins, but the Emergency Horizon Switch (the one with the copper wire around it) lasts 1:30 according to my POH. Nice to have, but still doesn't do anything more for you than illuminate the panel and keep you straight and level.
On your second point, there's no way to get an ASR/PAR approach after using up the battery power (30 mins on essential bus). At this point, all of your comms are dead and you're transponder is no longer transponding. (No need to get into a discussion on whether or not ATC will still be able to see you). Once you're down to the essential bus, you have under 30 mins to get on the ground, or get VFR.
-Chris
30 minutes in a sim (or using a GPU) and a 1.5 hr flight is definately not enough time for a G1000 checkout, in my opinion. I don't even think 5 hours in a sim is a long enough G1000 check out. I have over 120hr in a G1000 and there are still new things I find out about it.
If this guy is an IFR pilot looking to take the G1000 IFR, I firmly disagree with you.30 minutes in a sim, then a 1.5 hr flight is plenty if he's read the G1000 manual. It's not rocket science, presumably he's an IFR pilot so it's just a matter of finding out the slightly different way to do what you already know how to do.
