Wow! Haven’t heard that before.While it is allowed, I have had some buddies that have had captains tell them they couldn't use flaps 2, 10, and 25 because those captains claim those flap settings aren't in any of our profiles.
That’s pretty stupid, but so is having 9 flap settings so they cancel each other out.
i like my old days of takeoff/approach and landing flaps in one jet; and no flaps at all in the other.
Yeah mine are mostly either HALF/FULL or automatic with the gear handle. Whatever, they said I passed my MV so that's good enough for me![]()
Umm, that's five.The 737 can still be a 4 flap plane like the A320. Flaps 1, 5, gear down and 15, then 25 and 30 in quick succession.![]()
Umm, that's five.![]()
Only because culturally here, we call for it like that. I haven’t had anyone go from flaps 15 and call for 30. If you want 30, we usually still say flaps 25, then 30. You’re right that’s five, but in practicality you can think of the last notch as two quick successions.
I'm sure I'll figure this out on the line, but I still haven't been able to figure out what the appropriate delay in F25 is......like do you just say it and then immediately follow up with F30 (as I have been doing), or are you supposed to have a pregnant pause so everyone knows you did it?![]()
Nothing says you can’t go from 15 to 30 in terms of some limitation or restriction. Unless it’s in your training manual, the 25 thing is a weird-ism some pilots have to have a smooth transition to 30. It really doesn’t make any actual difference. I even go 15 to 40 for final flaps, if I’m planning on using 40. I don’t stop at 25 and 30 for a few seconds just because. Unless it’s some weirdo required thing to do at your shop, the airplane doesn’t care one way or another.
Why? What is the purpose for this cultural way? Just “how it’s always been done”?
Why don’t you quickly stop at flaps 10 from 5, before going to flaps 15….make that two quick successions?
*Laughs in Dial-a- flap*So what are your thoughts about flaps? When and how much? Techniques? I'd say that all these bananas flaps options are potentially the most confusing for my pea brain (I'm used to either up/half/full or just up/down). As @MikeFavinger astutely noted, I am one who will fly mostly 800/900/MAX with an occasional 700F. What's the finesse point? Speaking mostly to dirtying up, slowing down, terminal area stuff. The up and away config changes are fairly straight forward. I come from a plane that can basically do anything once you slow to 240, though it also does not really slow down and go down without speed brakes (which aren't limited by flap settings in that case). Though I have been taught over the years to die a little inside when you fail and have to use the boards.
Because the profile is that way. We’ll use flaps 10 if on GS and need to go down while still doing an ATC requested speed of 180ish knots. Flaps 10 officially isn’t on the profile view below.
Flaps 1 about 225-210.
Flaps 5 about 180-200. (Or around 210 if need to descend more).
Gear down, flaps 15, bug 15 or about 160.
Flaps 25, bug towards final target speed, and
Flaps 30 landing checklist.
If it’s flaps 40, I’ll still call 30 first, make sure we’re decelerating and below Vmax40 and then call flaps 40.
Full disclaimer. “Glideslope alive” as gear down flaps 15 and “approaching glideslope” flaps 25 are the official profile, just like it was for the CRJ, but reality is you could have GS alive waaaay out there and even capture way back at 4-5000 ft. Just do what it takes to be about flaps 5-10 and 180 knots until about 2000 AGL and then configure. In sim world do the exact profile, but real world, it’s okay to delay until closer in.
Point is, the profile shows that no matter how you configure, call gear down flaps 15, then have a callout for flaps 25, and then flaps 30/40.
No limitations per say, we can put flaps out up to appropriate placard speed (eg, 250 kts for flaps 1 and 5). But the profile I wrote out above is what most people do at our shop.My question is what is the purpose of that in the profile? Is there some performance or limitation reason that it’s that way? Or is it just that we’ve always done it that way?
My question is what is the purpose of that in the profile? Is there some performance or limitation reason that it’s that way? Or is it just that we’ve always done it that way? It’s not wrong necessarily, but it’s just a needless extra selection step.
