jhugz
You can grease landings in the Arrow if you keep the power in a tiny bit until round out. I land the Arrow just like the Seneca. even if its 200rpm, if you chop the throttle your producing negative thrust, bump it up a couple hundred to around zero thrust and the plane lands much better.
OFF TOPIC: Let me just give you a tip from experience on this site. Change your avatar.
