Still don't believe anything going 121 is considered important for the designation - sorry.
Not even when you have a bona fide medical situation on the aircraft?
Sent from my TRS-80
4-1-3. OPERATIONAL PRIORITY
a. Emergency situations are those where life or property are in immediate danger. Aircraft in distress have priority over all other aircraft.
b. Provide priority service to civilian air ambulance (LIFEGUARD), or military air evacuation (AIR EVAC, MED EVAC) flights. When requested by the pilot, provide notifications to expedite ground handling of patients, vital organs, or urgently needed medical materials. Assist the pilots of air ambulance/evacuation aircraft to avoid areas of significant weather and turbulent conditions.
NOTE-
Air carrier/Air taxi usage of “Lifeguard” call sign indicates that operational priority is requested.
c. Provide maximum assistance to search and rescue (SAR) aircraft performing a SAR mission.
d. Provide special handling as required to expedite Flight Check and SAFI aircraft.
This may have changed since I haven't been a transplant coordinator for about 6 years, but at that time, many kidneys traveled by 121, which was coordinated by UNOS, the national listing agency. There were some that became non-transplantable due to delays.Organs that need priority handling are always flown 135. I mean Angel Flight has even used the LifeGuard call sign - that makes me laugh!!! It is like me putting lights and sirens on to drive to the emergency department for work.
Diddo.I only file "Lifeguard" with a patient on board or enroute to pick up a patient off-base. Otherwise I'm just plain ole King Air blah blah blah..
We get it...medevac guys are badasses...
...apparently with small dongers.
I very rarely used "Lifeguard" even with a patient on board; whether rotor OR fixed-wing. With patients, I almost never used it rotor because I didn't mix in with most traffic anyway. And again with patients in the fixed-wing, I only used it when I could hear that the traffic was heavy, when the airport was IMC, and when I started getting ATC delays.I only file "Lifeguard" with a patient on board or enroute to pick up a patient off-base. Otherwise I'm just plain ole King Air blah blah blah..
I'm with I Money here, it is WAY overused...........
Couldn't agree more! This is the very same reason I used it if I determined that my route would not be the most expeditious while a patient was on board.........Every patient deserves to get to the hospital as expeditiously as possible. I never know anything about the patient when I file the flightplan nor do I care what the traffic is going to be. I file "Lifeguard" because I'm an ambulance and I'm going to get there as quickly as I can. I don't anyone would argue with me that air ambulance flights with patients on board are overusing the status. Now pilots that file it on an empty return flight...that's not right.
