Dugie8, @
MNFlyboy
I'm not an airline guy, I'm military flying big jets (or was until a week ago, anyways… class starts Tuesday for my new single engine ride!)... so I'm not sure about the OpSpecs side of the question having never seen them. Perhaps there is something in their that specifically prohibits a VCOA that makes the rest of this discussion moot. However...
I believe the VCOA (Visual Climb Over Airport) IS an ODP. So I don't think there is any real regulatory issue involved in doing the VCOA "rather" than the ODP, because the VCOA "is" an ODP. I base that argument on a couple of sources:
1. The TERPS manual (FAA Order 8260.3B
http://www.faa.gov/documentLibrary/media/Order/8260.3B Incl Chgs 1-21.pdf) chapter 4 describes the VCOA as an "an alternative method for pilots to depart the airport where aircraft performance does not meet the specified climb gradient. Development of a VCOA is mandatory when obstacles more than 3 statute miles from the departure end of runway (DER) require a greater than 200 ft/NM climb gradient." This description and the rest of the regulations involved in building the VCOA all come from the instrument departures section of the manual where all of the other ODP information comes from.
2. Section 5-2-8 of the AIM (about ODPs and SIDs) also states that "Some DPs established solely for obstacle avoidance require a climb in visual conditions to cross the airport or an on-airport NAVAID in a specified direction, at or above a specified altitude. These procedures are called Visual Climb Over the Airport (VCOA)." Seems to imply to me that VCOA's are a subset of ODPs.
3. At least 1 FAA document that I found relatively easily specifically spells out that the VCOA is part of the ODP:
http://www.faa.gov/about/office_org...0/afs420/acfipg/open/media/Hist_10-01-292.pdf. Of course, this isn't a FAR, so it probably isn't exactly gospel, but it seems to lend credence to the same idea.
If that's the case, then the other point that you raised still stands: Even if I am legally allowed to fly a VCOA, I'm still required to keep the airplane at least 35 feet vertically clear, or 300 feet horizontally clear of the obstacles (outside the airfield boundary). How do I confirm that I am able to do that in a VCOA? Well the answer comes from the TERPs manual. The VCOA is only authorized when an obstacle is outside of 3SM from the airport and it penetrates the obstacle identification surface (the 40:1 OIS slope) requiring a greater than 200'/NM climb to clear it. So they calculate an altitude that you will be climbing to within a particular radius of the airport (these become the ceiling and vis restriction), and from there you are expected to continue to climb at 200'/NM. By raising the starting point of your climb from ground level to the climb-to altitude you avoid all of the obstacles outside of the visual climb area (VCA). So long story short, by doing the VCOA, you are guaranteed to clear all of the obstacles OUTSIDE the VCA by same rules you would be clear of them on a diverse departure.
That still leaves the obstacles INSIDE the VCA. To calculate the climb-to altitude, the TERPsters find the highest obstacle within that radius (usually they use 2.8 NM plus the distance from the Airport Reference Point to the most distance Departure End of the Runway-- generally that's 3 NM minimum, and usually more). From the height of that highest obstacle, they raise the level another 250' and then round up to the nearest even multiple of 100 (plus any adjustments if necessary). So at that altitude, you are guaranteed to be at least 250' vertically above all obstacles WITHIN the VCA. So the only question then is the period from take-off to the VCA…
And from there you are expected to avoid the obstacles visually, which is why there are the higher ceiling and vis mins. But I don't read that as a violation of FAR 135.379. 135.379 just says to avoid obstacles by 35' vertically, or 200' horizontally (within the airport boundary) or 300' horizontally (outside the airport boundary). It doesn't forbid you using see-and-avoid to do so when in visual conditions.
To summarize, I think a part 135 jet could still do the VCOA legally, based on the above.
