Orange Anchor
Uhh, the L-29's spanked the L-39's at Reno. That said, I think the L-39's look way cooler.
In a somewhat cryptic and terse comment it said "Viper" was a modified L-29. Yes, I think so. The -29 is listed with max smash around 405 while the -39 is closer to 500 so someone had some nice magic.
The standard -39 uses a Walter jet engine rated at about 3800lbs thrust. T/O weight at 11,600lbs (3.05lbs/lb of thrust). The -29, comes in much lighter (7200lbs) with a 1960lb thrust engine (3.6lbs/lb of thrust). So wt/thrust ratio is not close. It has to be the wing. sort of like Vans RVs. Check the website and you will see data for the 150hp/180hp/210hp and not a HUGE difference in max speed. Like my Swift.. if it only went as fast as it looked.
FWIW, it says the -39 is the world's most popular private jet warbird with bout 300 flying in the US.
I didn't realize the huge price difference between the -39ZA and the -29.. $250-300 versus $100-150k.
Here's the kicker. An A-37 goes for more than $600k. I got one sortie into IV Corp in one. T-37 with J-85 engines. The routine was to shut down one engine enroute for best range. ??? Crank it up for strike and shut it down to come home. Crank it for landing.
http://www.trade-a-plane.com/clsfdspecs/823231 The 604th was the unit I got the ride with. (the ad says 1967..not. Didn't get there until 1969 and began replacing the F-100s. Good machine but not an F-100)
Not noted for being the nicest little machine to land but this would be my choice.
