HJB
Hopefully. Then again, this is corporate America we’re talking about.considering nobody went to jail for the coverup and obfuscation after the first two crashes, perhaps better late than never?
Totally waiting here to see the company get a slap on the wrist, the C-suite to keep on doing a heck of a job, and everyone else to stand around and go “well there’s really not much we could’ve done.”Hopefully. Then again, this is corporate America we’re talking about.
Interesting take, considering Boeing has no records of the work being performed.It's really simple.
"Door opened" versus "door removed."
Both require 4 bolts to be removed.
But only a "door removed" required a re-inspection to ensure the 4 bolts were added back on.
Work was officially written up as "door opened."
No follow up work required to ensure 4 bolts were on. Because the procedure written up this way didn't require it.
This is literally what happened. Why the Congressional hearings and criminal investigations?
Obviously we know now that if both procedures required 4 bolts to be removed, then both procedures should have had a re-inspection to ensure bolts secured both on. This problem is now fixed, and a blow out will not occur again.
Boeing admits it can’t find records on the Alaska Airlines door plug work
Boeing admitted in a letter to Congress that it can't find a documented record of the work done on the Alaska Airlines door plug and said no record may exist.www.seattletimes.com
Several of us sat around the pad and watched "Downfall" (the Boeing documentary, not the Hitler movie) - even though we were loosely familiar with it, the piece was a bit eye-opening and, this was probably intentional by the makers, a bit anger-inducing.
The fact that they had the ability to do a $2.5BN settlement to avoid criminal prosecution....ugh....
I’m sure you’d feel differently if your wife and kids were on those planes. In the meantime go color, and leave this to the people that are qualified.There shouldn’t be anything criminal about MCAS. Everyone has already forgotten the Lion Air plane had the same issue the day before the crash, and a more competent crew handled it just fine and continued to Jakarta and wrote it up improperly.
If that’s the case I’d recommend you never sit on a safety committee. They’d never fly again.There are many airlines in the world I’d refuse to fly my family on. Lion Air and Ethiopian both on that list.
A Boeing employee literally bragged that he misled the FAA.There shouldn’t be anything criminal about MCAS.
This is a bug, not a feature.
More competent pilots should - and would - have handled it properly and made a safe landing. As was shown the day prior for Lion Air.
While this is true, I don’t think it makes Boeing less culpable.Read the context of that, he said it was unintentional.
And no, the second part shows the airplane was absolutely controllable, had they been competent pilots and not button pushers. The Lion Air Capt was able to keep it safe / stable. His problem was a FO with dyslexia who couldn’t help with jack. In his desperation he gave the FO the controls so he could read the QRH himself. Unfortunately, he didn’t brief the incompetent FO to use the trim switch constantly. FO knew only to push/pull the yoke. All dead.
Ethiopian, stick shaker from the onset at takeoff and 3 times the CA (pilot flying) asked for the AP on! AP on. AP on. That tells you all you need to know that this is a button pushing crew, not an aviator crew. All dead.
Perhaps lesser competent crews would have figured it out if they’d been told about it
