I have recently started taking flight lessons, and one of the things that worries me is the size of the blind spots on GA aircraft.
The text book essentially says: "Just keep scanning the windshield" Given that there is a possibility of someone descending or climbing into you, or that you descend or climb into someone else, I don't think it's enough to just scan the wind shield.
Apart from following all the rules/suggestions (such as 45 degree downwind entry) and using proper radio communications, is there anything else that I can do?
Couple of thing that I already know:
-in a high wing aircraft it's a good idea to raise the wing prior to turning
-long final should be checked while on base leg
-left and right should be periodically checked even when straight and level
- Make S-turns while climbing. (Is it adequate? Should I do the same while descending?)
- Request flight following when possible
And, a couple of things that I came up with on my own: (not sure if the following actually works, please let me know)
- Avoid prolonged climbs or descends in the same direction
- Make slight heading changes while en route
- Avoid initiating a climb or a descend without changing your heading.
- Make clearing turns every time you get close to an airport. (Is that practical?)
Again, the questions I have:
Is there anything else that can be used to increase the effectiveness of "seeing and avoiding"? (primarily for avoiding aircraft above and below you)
Are the techniques that I have listed of any real use?
Thanks in advance!
Thanks in advance!
