milleR
Shhhh shh shh shhChemtrail spray pod up top!
*don't just spray 'em, barium!*
Huge face is EWWWUUUUUGGGGGEE!![]()
I'm surprised this one never made the thread. I had an offer to fly this for a company that operated out of Tara Field, south of KATL, but had to turn it down.
It's the Ted Danson of planes.Huge face is EWWWUUUUUGGGGGEE!
I canz be a 747![]()
Ruined twice![]()
I'd mostly agree with that list except I would maybe put MU-2/Metro ahead of Pistons just based on what I've heard about those two types.Based only on what I've flown and ranked by overall operational difficulty. I realize most HR departments don't give a crap, but they should!
-Piston
-MU-2/Metro because they're CRAZY
-Unpressurised turbine
-Other pressurized turbine
-Part 25 props, using the Brasilia a reference. By far the easiest and least experience building of the lot. CRM IN the plane aside, but even that just isn't hard at all to figure out. If you're not a richard and know how to disarm a richard. Learned in life...
-Jets. All the former freight guys would probably put them here as well.
For career advancement
The exact reverse of that list.![]()
My humble opinion of course. I'm braced and ready for your comments!![]()
I can't believe you unfriended me on FB. I literally cried for 24 hours straight.
Systems wise and the likely hood of dealing with an emergency where, if you're an idiot, you'll probably die. However, operationally, piston freight is the hardest and most dangerous flying I've ever done. No power if you get iced up. No power to climb above the weather in a pinch. Minimum avionics. Ect. ect. ect.I'd mostly agree with that list except I would maybe put MU-2/Metro ahead of Pistons just based on what I've heard about those two types.
Sweet Jesus that's nasty!The beat up Shorts I fly is probably the ugliest. It's fun to fly, but I really get my kicks flying Metros
I'll agree with you there. The Piston I'm flying freight in now (PA31) is less badass than a 210, but the Turbine guys still have it better in terms of aircraft utility.Systems wise and the likely hood of dealing with an emergency where, if you're an idiot, you'll probably die. However, operationally, piston freight is the hardest and most dangerous flying I've ever done. No power if you get iced up. No power to climb above the weather in a pinch. Minimum avionics. Ect. ect. ect.
Metro/Brasilia guy here. @Boris Badenov flew the MU-2. I think he might agree that Flight Express flying was the hardest.
You forgot the Lear 23 up there between the Tom and @Boris Badenov's favorite plane.In order of awesomeness:
F-14
Metroliner/MU-2
most airliners
most business jets (not Citations)
1900
402 (Cessna, not Beech), Navajo/Chieftan - all recips, but twins
Caravan
Single engine piston poppers
The secret to flying in Shorts is to get some trim in there. Else you might over-stress the main spar.The beat up Shorts I fly is probably the ugliest. It's fun to fly, but I really get my kicks flying Metros
Don't get me wrong, at AMF, the Metro is the hardest to learn and pass a checkride in, and when something breaks, can get pretty nutty. Bad turbulence/crosswind on final/flare is difficult as well, but the day-to-day grind is just easier. Main thing is loading. They take long enough to load that there's plenty of time to balance your other duties. The 99 was harder on the ground. I didn't fly the chieftain.I'll agree with you there. The Piston I'm flying freight in now (PA31) is less badass than a 210, but the Turbine guys still have it better in terms of aircraft utility.
