I’m much like you in the sense that I prefer to fully understand concepts and what it is that I need to know, and then some, versus just memorizing questions and answers to pass a test. At first I began reading all those PDF files you mentioned, some hundreds of pages long, and then using Sheffield’s app to recall the information I retained. After reading weather theory, AIM, and The graphic/non graphic weather pdf, I was told most of the remaining knowledge can be more or less memorized. I have all these PDF files saved on my iCloud and I will be going over the graphic/non graphic weather one again here soon to master weather charts. Like others have said above, I’m assuming that mastering charts will make schooling easier.
I saved sections of FAR/CFR for quick access and have been looking up questions myself to familiarize myself with looking stuff up more easily.
I think I’m just nervous since I know the school I’m going to is a great school, at least by what I’ve heard from others and by reviews, therefore I’ve set a higher than normal standard for myself to grasp everything before hand so I can pass and make a career out of this; to succeed at it and make a name for myself.
If I come out alive Im intending on making a YouTube channel with all recommended videos that have helped me understand concepts for others like us who are diving into the field, or intend to, without having had any experience once so ever. From weather theory, reading graphs and charts, to understanding aerodynamics, I’ve found many videos pertaining to ADX material that I want to bundle up in one place via a recc channel. I’d gladly make videos of my own but I’m not in the field yet. Just yesterday I watched a few videos by the same individual going over how to find/File for alternates, read ILS approaches, which was more practical for me than reading how to do so. I sent them a message asking for more videos and how helpful they were but given the views, they aren’t making squat for the effort. I’m assuming they used the videos for class and just needed an easy upload resource. Anyhow, we shall see what comes of this. Let the studying commence yet again.
Thruve,
One big reason I prefer to understand something vs. memorize it is if I freeze up during the test, I can REASON my way to the answer. Also, much of the material you WILL see again! You'll see weather theory, non-graphic WX, and non-graphic WX within the first week of class; I guarantee it. If you make it to the performance graph pdfs, you'll see that again too. Now, granted the graphs are for a B737 while you'll study the B727 in class, but they're both BOEING PRODUCTS; as such, if you can figure out the 737 graphs, you'll have no problem with the 727 graphs, either. Aircraft manufacturers like to do their performance tables, charts, and graphs a certain way, so if you understand one of them, you'll understand all of them from that manufacturer; Exhibit A is the Boeing graphs. So, if you go through the Sheffield pdfs, not only will you do well on the ADX; you'll be prepared for class too because you will have seen much of it before.
Also, they give you access to nice PowerPoint presentations on how to do the graphs, deal with the HSI questions, etc. I would DEFINITELY look at those. The HSI PowerPoint was a godsend to me! They give you some quick and dirty tricks for figuring out those questions. You'll NEVER see that again after the ADX, but it's there. Just follow Sheffield's advice for the HSI questions, and you'll be fine.
That's not to say memorization doesn't have its place; it does. You'll need to memorize the abbreviations for non-graphic WX; symbols for graphic WX; you'll DEFINITELY need to memorize the HSI questions; and you need to memorize the answers to the BS questions like do you have enough runway to stop if your engine dies. There are certain things that are better off memorized, because you'll never see those things again.
What I really like about Sheffield's pdf files are: 1) they explain WHY one answer is more correct than the others; and 2) they provide references for further study. They'll point you to the AIM, the PHAK, the IFH, etc., so you can study more if you like. I didn't hit the books on everything, but I did dig deeper into certain subjects that fascinated me, such as swept wing aerodynamics, critical mach number, etc.
You seem to have the desire, which is a large part of the battle. I think you also have the right mindset. Between the two, I think you'll do well. Good luck!
