TUCKnTRUCK
That guy
I knowI'm saying "gun to the head" is ineffective. Nobody performs well in fear.
We are on the same page here.
Wait, so you did 425 FO ATP's and or types in August of 2012 (4%)? WOW! I had no IDEA the downtown offices were that efficient.Y'all are aware that the failure rate has remained at roughly 4% with a spread of 3% to 7% right? Ironically, the PC failure rate and ATP failure rate are very similar.
I am not defending anybody, but will say that some of the things folks say they "failed" for are NOT the reasons why the examiner wrote the pink slip. Its rarely "1 thing". You don't hear folks say "I passed due to this". If it's not in a book you have been given or training received, you can't expect someone to know it. I don't know how many rivets are in a -200, but I would expect someone to know the "normal" voltage of a battery AND the min voltage to start the APU. Why? It's in the CFM and SYS manual AND relates to line ops. It's also trained in ground, GFS, and sim training. Joe knew it, and had an EICAS page to look at to refresh his memory (he had it immediately from memory). If you can't change a situation from the cockpit or understand the problem from an EICAS message there is a QRH enroute or a call to mx at the gate.
If someone fails something, there probably was a lack of training somewhere, but there is also the few who don't study and/or ask for help on a certain piece of info or procedure. I have had orals and check rides with many named into derogatory "labels". I was tested on a range of all info I knew from the books given. Some guys want to walk into "bonus point" territory and I don't know why. It's a fun challenge, but every time it was known to see how far I knew things, and have seen other orals in the same manner with guys who are equally sharp and well prepared.
If you need to know that the ext power connector is in junction box XX, you need to be a engineer and not fly the A/C. If you know that 400HZ/115V power will show the avail light on the overhead panel and that the aircraft uses that to power the aircraft through TRU's with a 100amp max each, you will be fine.
higney85 said:Y'all are aware that the failure rate has remained at roughly 4% with a spread of 3% to 7% right? Ironically, the PC failure rate and ATP failure rate are very similar.
Nope. Going by stats that were given.Wait, so you did 425 FO ATP's and or types in August of 2012 (4%)? WOW! I had no IDEA the downtown offices were that efficient.
17 FO's who were up for their ATP and or PIC type in August failed, at least that's what 3 of the trainers couldn't stop chuckling about in the halls. A number (which I took for fact) that was reiterated during one pilots retraining. Are those all lies and fabrications? How are you getting that number:
That proves my point. Failure rates should be in the .05% to 1.5% range.
Very true.
When you go into the 'bonus territory' as you say doesn't that lead to a lack of standardization? I get the fact that done Check Airman want to teach, that is great, but don't hold it against an applicant if they don't know.
Have you been through any training under "pinnacle"?
And where does .5-1.5% exist? Is it a known number? FAA mandate.
Yes we can. Before you stop me, yes we can. You see if it is denied often enough people will move onto other things and the training department will get saved the embarrassment meanwhile it will be fixed by the new guys and hopefully everyone will just forget their friends on the street or with multiple failures. The guys we bring back will be so thankful and the ones expunged they'll want to keep it quiet because everyone knows how pilots feel about guys with one never mind multiple failures on their records. What was it someone on the interwebs said often and early every time someone would bring up what a side show Hunter and the insane clown posse of merger reps were, "it's all politics" or something similar.It is well know about the NMFC and the games that have been played in the training department. We can't pretend they don't exist.
If I had to bet, Seggy will be singing ," can you feel the Luv tonight" next year![]()
Just wait !!!Swing......and a miss.![]()
DEFINITELY not.
The funny party is, they will never see how stupid it is, until they get out... Then its like, mum... what? OverJesus. Bury the freaking hatchet already. This all still sounds like "We're Mesaba/Pinnacle and we're better than the other guy. " Honestly, who cares. It's all one company now, friggin ACT like it. The divisiveness that I saw daily was one of the things that burned me out on pretty much everything. Who cares if a legacy Pinnacle guy did this or that or a Mesaba guy would have let that slide. Work together. It's been two friggin years or more sine the MECs "merged" and it's still like two different airlines. I swear, it's ALMOST as bad as Airways.....
I've noticed from Pinnacle guys past and present that there's a feeling Mesaba and Pinnacle need to merge up. There's this third company out there. Oh don't roll your eyes just yet. At first in the training center I said "eek, lot of tension out there," but having being out there on the line I honestly would be surprised if any Colgan guy walks into the crew room, ever. You better believe there's a lot of divisiveness, and Pinnacle is leading the charge.
I got told in the crew room the other day that the Colgan guys should all be fired from the company because they ran the place into the ground and ALPA should lead the charge. Not only that but if Colgan had only agreed to DOH we'd all be fine. I understand why some Pinnacle people pilots stay out of their own crew room, it's a mad house. Plenty of empty gates to sit at. Everyone at JFK needs an enema in my opinion, and a good long massage.
This company and it's pilots will take years to merge and to feel together, but by then we'll all be gone or closed down. In the meantime I don't mind everyone throwing stones, it gets the stress out, and so far in the cockpit I've not had any safety of flight issues due to angry pilots. So relieve stress however you have to, just as long as it isn't in the cockpit. However, let's not get too high and mighty about Mesaba guys not playing along with the band, especially while I watch the band beating up the brass section from junior varsity.
P.S. It's a lot easier to start calling yourself Pinnacle when you get de-fenced because you aren't always logging into the myMesaba site, the mesaba crew web, and going into the Mesaba crew rooms. This isn't red book green book thing, this is a botched merger and it has consequences. Kind of like treating 400 or so of your own pilots like pariahs.
