Roger Roger
I am le tired
Runway inspection, if you put a gun to my head and forced me to make a guessOne would think the maintenance crew wouldn't be on the runway 3 minutes before it opened. Why wait until the last minute?
We need to be reminded that the airport grass is being mowed on every atis from April-October
Well, as a CA I will tell you I welcome any speaking up. In the heat of stuff going wrong or when we get saturated it is hard to keep a clear mind and recognize when somebody needs a safety pause. I LOVE it when an FO tells me they need a minute. I try to ask if anyone needs a safety pause when crap is hitting the fan but if I forget I really love it when an FA or FO says that they feel uncomfortable, unsafe, or feel rushed about anything and everything.
Closed is closed. One would think that the prudent thing to do would be to wait until tower opened, then query ground/tower on whether the runway is formally open yet or not. Of course, you’d have to be up on freq in the first place in order to do that. I guess they didn’t notice any other aircraft taxiing out for departure, going to the other runway either.
Like the yet another memo about auto brakes?
dang yall have brake temp gauges? its been a disconcerting change coming from the bus, especially while using max brakes on quick successive flights every leg thru the islandsI arrived at yet another aircraft with hot brakes to start my latest trip. They were smoking but within limits. I have no idea how one gets the brakes that hot. I regularly do the post flight in outstations and I can put my hands on the brakes because they are barely warm. When doing the walk around I’m regularly seeing smoking or brakes fart too hot to touch. This time the brakes were 419C and the limit is 425C.
The training department needs to focus on practical issues and clear easy to understand language or this will continue. In my opinion it’s pretty bad and needs to change. To me at least it’s quite embarrassing.
Just using auto brakes reduces the temperatures quite a bit since the braking is more even and therefore energy is spread out through all 4 wheels.
Speaking with the MX guy we were lucky the brake pads were brand new pads and they could absorb more energy than nearly done pads.
I’m curious about the dispatch paperwork (not pointing any fingers). Do your shops include runway analysis or performance numbers for runways that are unavailable at the planned departure time?
Huh? This is how the DEN brake seizure happened.
AB 3 used on a hot day and one TR was deferred. And they were slow to deploy the remaining TR. Pulled off the runway, had to sit for a while so the put the parking brake on, and the brakes seized. Couldn’t taxi.
Stop using AB 3 or MAX when it isn’t necessary. Even speed brakes and 1 TR can be used to slow to a slower speed before applying light manual brake pressure
He is right, AB is simply requesting a deceleration value. It applies brakes (if needed as a result of what AB setting you pick) it applies brake pressure better than a human can in terms of evenness and pressure.
With one TR deferred I still wouldn’t select AB3 in DEN. Selecting AB1 wouldn’t engage brakes with the TRs deployed. Even AB2 might not. Selecting AB3 in Denver is insane even with both TRs deferred. I wouldn’t select AB3 in Denver with a zero flap landing. It’s ludicrous to select AB3.
And unless it’s a short / contaminated runway, I don’t know what human is touching manual brakes at this very high speed regime to begin with.
Unless I’m BUR or SNA, or a crosswind, no AB and I don’t even touch the wheel brakes until below 100 kts. Have yet to get shuddering brakes with this technique on a hot day.
Stop using AB 3 or MAX when it isn’t necessary. Even speed brakes and 1 TR can be used to slow to a slower speed before applying light manual brake pressure.
Where are you guys landing where you're smoking the brakes to limits? This sounds like a pilot training issue. We routinely get hot brakes in Denver, but for crissakes you've got 5 miles or runway out there. You could practically roll to a stop without touching the brakes before the end! No reason to get on the binders above 80 knots.
