I'd say that if your normal braking technique involves stopping halfway down the runway, it probably isn't the right technique for hot/high/fast landings with a full load of people. But what do I know? I did grow up in a plane with fairly weak brakes and a propensity for brake fires/melted fuze plugs/etc....so over the years (in that plane), I have made a habit of not stomping, and generally not using them for much of anything above 100 knots unless really needed. Too many other drag devices that are more effective at high speed (especially in our plane).
Unless it's a short runway like SNA or BUR, if you are landing and getting on the brakes, you are doing it wrong.
As long as it's a decently long runway (7500 or greater), my hot weather landing:
NO Autobrakes
Flaps 30, maybe 40 if winds aren't bad.
Max reverse thrust (full, beyond detent 2).
Do not touch brakes until below 100 knots.    Now come on the brakes.
CA advantage is the HUD.    I see the deceleration carrot.     Upon landing, I see in the vertical direction 1, 2, 3, and MAX.    It shows the "equivalent" braking.     By merely cranking out full reverse thrust, the deceleration carrot shows the equiavalent of Autobrake 2.5 to 3.     As you slow more, then reverse thrust isn't as effective, and the carrot starts coming towards 2.        Waaaay too many times I see FOs land with no AB, touchdown, get the reverse out, but then get on the brakes.     The carrot INSTANTLY goes towards AB MAX - the equivalent deceleration to max autobrake use.     Sometimes, even beyond that AB MAX.    I tell some guys that, they can't believe it.    "I was gentle on the brakes, it didn't feel that bad."
Yeah, but it is.
If it's gusty, I do AB 2, and max reverse thrust and leave AB 2 on, max reverse on, all the way to ~60-80 kts and then override the brakes.     Your AB will initially kick on after touchdown, helping in a cross wind.   Once reverse is out, AB lets up as the deceleration is beyond decel 2, and then comes on slightly again as the plane slows and maintains a decel of AB 2 the entire way with the TRs helping.     This also helps reduce brake temps.
