So what are your thoughts about flaps? When and how much? Techniques? I'd say that all these bananas flaps options are potentially the most confusing for my pea brain (I'm used to either up/half/full or just up/down). As
@MikeFavinger astutely noted, I am one who will fly mostly 800/900/MAX with an occasional 700F. What's the finesse point? Speaking mostly to dirtying up, slowing down, terminal area stuff. The up and away config changes are fairly straight forward. I come from a plane that can basically do anything once you slow to 240, though it also does not really slow down and go down without speed brakes (which aren't limited by flap settings in that case). Though I have been taught over the years to die a little inside when you fail and have to use the boards.
