ppragman
No pasa nada.
Did you fly the NG? I have a question.
I've flown the /45, the /47 (classic series 10 but not NG), and the /47 NG. What do you want to know
On an NG, can you do a complete and total power cycle without cutting the engine? I understand the systems, but do you know of an issue or a "gotcha" that doing that would create? Killing all the power with the engine still running?I've flown the /45, the /47 (classic series 10 but not NG), and the /47 NG. What do you want to know
No I was thinking more at the hold short vs in flight. To clear a known CAS message you knew would go away with a reboot.Well, to be frank, I never tried it, and it was pretty much verboten at our company to screw with the overhead electrical panel on the NG unless the checklist told you to. Presumably you could throw the red "DON'T F-ING TOUCH ME!" switch, but if you did all that it'd be quite a while before the Honeywell came back online? There's a ton of relays controlling everything
if you're talking, "moving all the switches to off" then turning them back on in flight... then looking at the diagram, I don't see what would remain powered, but I haven't flown it in almost 2 years now. There may be some sort of directly wired stuff that keeps the circuitry to the Gen powered?
If you've found the Lord and it helps you I suggest you stay with it. Otherwise you might've offended those that do by using His name in vain.Jesus
Roll-your-own abnormal checklists: Nice!
Everything offends you lolIf you've found the Lord and it helps you I suggest you stay with it. Otherwise you might've offended those that do by using His name in vain.
It was an amber "Hydraulic" I knew it would clear and we shut down for the reboot. But as a thought exercise i wondered if I could have done it engine running.@Roger Roger - would probably know.
Honestly, I never had any CAS messages flying the thing if I followed our start up process to the letter. I had all sorts of issues when I didn't wait until I had Texture on the Honeywell IMap display. Never had to do that. I'd imagine it'd be fine? What kind of CAS message are you getting?
You actually want to get thought checked out.It was an amber "Hydraulic" I knew it would clear and we shut down for the reboot. But as a thought exercise i wondered if I could have done it engine running.
I'm not offended, I'm not religous, although I spent enough time in religous schools to know that some people might be offended. I dare you to try and offend me.Everything offends you lol
The QRH is missing a note that accompanies the procedure in the PIM. If there are no maint facilities available after a visual inspection you can reboot and see if the message comes back.There is no reason you couldn’t do a full reboot with the engine running, but as far as I know there is no checklist that says to do it. The avionics can be quite persnickety about the order of startup/shutdown so you’d need to be cognizant of that.
Of course I am a model pilot and would never deviate from what the QRH says but I have heard of people who have had a CAS message on startup that they thought would clear with a power cycle who instead used their system knowledge to do a reset of the effected LRU (say, a radio unit or the fuel quantity computer) via circuit breaker and according to those people who shall remain anonymous until statutes of limitations expire it worked out fine unless something turned out to be hard broke.
BRILLIANT!The QRH is missing a note that accompanies the procedure in the PIM. If there are no maint facilities available after a visual inspection you can reboot and see if the message comes back.
Hey I hear ya. Im a mechanic at heart. But if they can eliminate us they can eliminate you. Hell anymore the airplane troubleshoots itself and just tells you what component to change.BRILLIANT!
That's not a very nice thing to say, I'm offended.Hey I hear ya. Im a mechanic at heart. But if they can eliminate us they can eliminate you. Hell anymore the airplane troubleshoots itself and just tells you what component to change.
I'm offended.
He’s well under par in the JC “goofy conservative golf” tournament.That took way less time than I thought it would.
