Being PC and incorrect are different thingsGeez some bitter folks around here. I wasn't giving any financial advice. Just stating the obvious. Didn't know we needed to be PC.
Sent from my SM-G900V using Tapatalk
But if you truly only need 1 flight to get to work, what difference would it make? Your only option arrives 5 min before report. You don't make it, the flight you were to operate gets canceled. I'm not sure how the pilot wins anything in that situation with management
You're welcome (and it's not HIS rewrite).
You should have called them before the company flight left and made sure they got you on it.I had called Crew Sched two hours prior and informed them that flights were looking bad, they ended up not even giving me a sad because they were appreciative that I kept them in the loop at the first sign of trouble.... You're the second one to say communication was an issue, that was not it. I even called the BCP and told him that if a company bird hadn't left me in Portland I'd be there at the current time... I had a 9pm show and my first call to Crew Support was 7pm. During a normal day that is still two more flights between the city pair to catch a flight and be there prior to report. Not really sure how much more clearly one can commute an issue than that. I'm all ears if anyone has advice though
I'm all ears to learning! I'm saying the bonuses will get taxed. No?Being PC and incorrect are different things
Why would you think bonuses would be taxed differently? Some may be withheld on larger lump sums, you'll make the difference back on your return. You're taxed at the same rate.I'm all ears to learning! I'm saying the bonuses will get taxed. No?
I didn't mean it was taxed at a different rate. I was just saying since it's so big, more is taken out....which we all obviously know. Not sure how my wording was though.Why would you think bonuses would be taxed differently? Some may be withheld on larger lump sums, you'll make the difference back on your return. You're taxed at the same rate.
You'll pay taxes on the bracket you fall into.I'm hoping that's true with the return. My 10k bonus after taxes was 5800. I had to do a double take, then raised my hand and asked where's the rest of it?!?
The PPS and performance bonuses make pay here much better than a bottom feeder regional that's going to give you a heavy taxable check of $20,000
My boss wants two flights.To make a short story long:
With a clause that says, say, two flights, you might have to try to commute out a night early. Previous company required proof that you tried multiple flights. OO has no clause and there's no fuss if you try one flight and miss it with a large caveat that you don't abuse that. You can't be calling in every week saying you missed your commute. You'll get a talking to. But if it's infrequent there's no questions asked and we don't have to have proof.
Yes.You should have called them before the company flight left and made sure they got you on it.
Yes.
In fact, if it came to it, Flight Control could put you on the release, which trumps just about everyone trying to sit on 1P.
Were I still a 175 pilot, I would love to have one hostage on the flight deck to talk about FMC 27.1.Sure they can!! They're even putting Honeywell people on the Jumpseat
Good for him? There's no company policy, so how can me make his own policy up?My boss wants two flights.
Which is (1) what it should be, and (2) why it should be written down somewhere.
That poses a problem sometimes. There's a lot of cooks in the kitchen here and different people do different things. Sometimes that might have worked. Depending on who was working. Other times it wouldn't work at all because "there is absolutely no way WE can put you on a DL painted plane when you're going to work an AS trip."You should have called them before the company flight left and made sure they got you on it.
Uh, he can, because there is no Company policy.Good for him? There's no company policy, so how can me make his own policy up?
Sick or unavailable at notification is a SAD, as is failing to show.As far as getting fired for calling in on the commute bit...I don't know what happened. I read his post. To me it sounded like he sprained his ankle, then tried to sit reserve days "risking" not getting called. Then when he did get called he said he couldn't fly. Then he did it again the next day. If that's what happened (I could've misinterpreted it but that's how I read it. Not: he had the trips on schedule then sprained his ankle and called in) then that's a big issue right there. The company has a huge issue with people trying to risk it on reserve and calling in sick when CS calls you for an assignment. Especially while on probation.
For those who are wondering, call Flight Control. Colloquially known as Dispatch.Not sure if Crew Sched could have gotten me on that flight. Maybe by putting me on a dead head which was not allowed as PDX was not my domicile. Now if I had called travel center, they may have been able to help. That I really kick myself about for sure.
