ahsmatt7
1. The hour requirement for BOTH categories is too low. I would say that 1,000 hours in the focused program with a clearly standardized curriculum in both solid academics in understanding flight theory, systems, IFR procedures, TERPS/PANS-OPS, ATC procedures both FAA and ICAO, regulations, CRM, etc, in an accredited 4 year program that is continually monitored to ensure the accuracy of the programs and academic standards. Military flight training programs would meet this requirement.
2. Non-academic program should be a minimum of 2,000 hours with comprehensive testing required on the above topic areas. These tests would be more in depth than the current ones, including oral exams, and also the requirements for the examiners in both categories would be rigorous to ensure they actually knew this stuff.
Again, this is utterly lacking in GA today. If it were not we would not have inane threads with people claiming lift was "partly Bernoulli and partly Newton" etc.
I don't see the point in doubling the hour req. just because one program is deemed "academic" while another program is not.
If someone wants to fly commercially, every pilot should be trained in the same manner. Just because a professor is teaching about the IFR system doesn't make it a magical experience with a ton more knowledge and wisdom being thrown to the students. If a standardized curriculum is desired. Then EVERY pilot wanting to go the commercial route will need to learn and understand X, Y, Z and ABC.
So that being said here is my req.
1. If a student goes through an aviation college, he/she will need to learn about topics X, Y, Z and ABC and take an overall cumulative test over all the things they have learned since day one. (the test is discussed further down in the thread) This test will be displayed as an endorsement on one's certificate. Along with 1000, hours of actual experience the endorsement will be the only way someone can go the 121 route. Also, a minimum score of 90 must be obtained.
2. If a student does his/her training through a mom and pop flight school or a flight school that doesn't have "university" attached to it, he/she must DO THE EXACT SAME THING AS ABOVE!!!!
No one should have less or more requirements and less standardization just because of where they are learning to fly. There is also no point of doubling the time requirement. Hell those extra 1,000 will most likely make the Part 61 guy/gal hell of a lot more experienced than the university guy.....no matter how much class time the university guy had.
In all honesty, there shouldn't even be two sets of regs regarding flight training. Every applicant no matter where they learn should be req. to learn and demonstrate the EXACT SAME THINGS.
(The all caps is not meant as shouting....its just meant to stand out amongst all the other words)
This test will be partly oral and partly multiple choice. It will test the applicant on EVERYTHING. Not just what "seagull" mentioned, but anything and everything regarding aviation. This test should be made very difficult. The questions shouldn't be the EXACT SAME questions in study guides. They can be the same type but with different numbers and no one should be able to see the test before its administered.
