mastermags
Well-Known Member *giggity*
Be that as it may or may not be, it is the exact same language written in our current contract. If wheel spin-up is what they want to use then they could have by this point.
That's a confusing way to put it
I've always seen that expression rendered "be that as it may," but that may, or may not be the correct way.Ok, it may not be then
Forget what?Forget it
I'm guessing he's still upset about Saturday night.
The technology definitely exists. Wheel spin up is all recorded on the FDR. All it takes is a couple of clicks on the ACARS to change pay parameters.
It is for the ERJ, but not the CRJ.
Edit-- I'm not saying it can't be programmed, or captured as a derived parameter on the CRJ ACARS. I'm just saying it's not a recorded parameter on the FDR.
But Gps derived ground speed is.
Yeah, but it is horribly unreliable below 50 knots or so. It wouldn't be a good option. The best option would be to connect to the prox system directly with the ACARS and look for wheel movement. I'm not certain if the current ACARS wiring configuration captures that parameter though. It prob would require some rewiring.
Yeah, I'm just saying the parameter is shaky. It might be good enough for this purpose, but it SUCKED for the level of detail that we wanted for FOQA. It gave us lots of false positives when looking for aircraft taxi events. False positives = a ton of validation work, so we abandoned the parameter, and used derived parameters from a few other sources, like N1 > idle combined with a heading change = aircraft in motion, etc.
It's entirely possible that PSA has a different setup than ASA though. Maybe they had wheel motion in the FDR bus, but I figured that most CL-65 had the same configuration.
(Sorry for the off- topic post.)
You mean you guys LOOKED for guys taxing too fast?
Let me tell you a funny story about negotiations for contract '04 on this side...
The company thought our guys were involved in a work slowdown, so they were hanging out around the airport with binoculars, and if guys weren't taxing around with the speed brakes up (wheel speed over 25 knots and thrust below a certain angle, so basically over 25 knots) they were getting called into the CPO to have a discussion about their "work slowdown."
At 25 knots.
We taxi like Southwest over here.
Nah, we were looking for aircraft configuration changes during taxi. We needed a reliable way to tell when the aircraft started taxi so we could chart the average time that the crews set flaps for takeoff. (We had a few attempted takeoffs with flaps at zero.) FOQA is about aggregate data, not specific people. We actually used the data to drive a checklist change.
Ewwww.You mean you guys LOOKED for guys taxing too fast?
At 25 knots.
jtrain609 said:Look at our data too? It happens about 2 minutes prior to departure with the old schoolers. Oh and there's that pesky gust lock...
