Seggy
Must be the position of the moon
Wasn't there a American Eagle Saab or ATR or something that crashed and killed everyone because they went into Beta during flight? I recall, because they had to put a WoW logic so that they can't do that anymore in the Dash-8 after it happened and I learned about it in systems class.That is a good way to bend metal and/or get yourself killed.
Was that something you were taught or is that something you picked up? Regardless, NO ONE SHOULD DO THAT.
Hopefully it's not with the Obamalove they wrap themselves in.
8 seconds is what I'd expect from an old water-injected 707. I claim no experience in a CRJ of any type, but 8 seconds is a very, very long time, and probably unrealistic.
I don't think it's 8 seconds. I've got about 2000 hours in the plane and I don't think it's ever taken that long either on the ground or in the air.
It is what it is, and it is 8 seconds
I'm not arguing with you; like I said, I've never flown one. Just find it strange for a smaller high-bypass turbofan. I just looked at my wall clock and counted out 8 seconds, and that is a heck of a long time.
Totally agree.
And I wasn't trying to argue it back, just saying that it was a major topic of discussion during our last ground. I am no CRJ expert.
ok so here's a question I have for you turbo-prop fans, on right engine start on a KA, right engine lights, idles at 52% in low idle. Gen on, charge up, gen off. Left engine, ignition and starter on. (Notice I never moved the condition lever to high idle to increase N1 to 70%). Right Gen on, Left condition lever to low idle. As the left engine spools up, the right one, due to gen load, spools down to as low as 46%. Once the left is started and the starter is disengaged, low idle comes back up. What's the theory on how low a PT-6 would have to go before it quits? I've also watched the ITT during this, and although it increases significantly, it never gets close to red line.
Thoughts?
That's true, plus you're close to losing the secondaries due to low fuel pressure.That's a very good question. I'll take a shot in the dark and say upper 30's for the N1. My theory is because since the gas turbine is still spinning, everything on the accessory case is still working; high pressure pump, oil scavenge pumps...ect.). As you are getting into the upper 30's, there is a insignificant amount of airflow for proper cooling, and you still have all primary and secondary fuel nozzles pumping out fuel. Therefore, I think the engine would temp out around that range instead of quitting.
Interesting that you had quicker response down low. For us the opposite is true.....better throttle response in mid range to higher power settings.
I'm not afraid if jet fuel will hurt you (it probably causes cancer) but the smell doesn't leave you, especially if you get in on your clothes. Might not matter in the airline world but in corporate jets whether or not prist is required or recommended is a fair amount of money for your particular operation. Start a jet engine with a 20 not tailwind and see how hot your start is. Spool time has already been discussed.There aren't many general rules for turbines that I can think of offhand. None of these four matter for all turbines. I'm not sure what you mean about the fuel either, it's just kerosene, it won't hurt you. Obviously you don't want to bathe in it or drink it, but as far as aviation fluids go it's pretty benign. 100LL is more nasty than Jet-A.
Sent from my Galaxy Nexus that ate your iPhone.
And if on the start sequence you forget to turn on the igniters, DO NOT turn them on after fuel has been introduced. I know a guy...
(No seriously, I know a guy that did that, it wasn't me)
I've only flown 1 model pt6, but the igniters come on with the start switch. Up and you get the starter and igniters, down is starter only.... but you have to hold it down... seems like it'd be incredibly hard to make that mistake.For PT6's, know your starter limitations, and know how long a normal start takes. The difference between those two is the amount of time you can spool the engine to bring the ITT down.
Yeah, can't say I ever personally experienced an eight second spool time on the CF34s. Maybe if they had been at idle at slow airspeed, but even then, I never removed it being that bad.
