C079.
Operations Specifications
IFR Lower than Standard Takeoff Minima, 14 CFR
Part 135 Airplane Operations – U.S. Civil Airports
HQ Control:
HQ Revision:
04/25/08
060
a. Standard Takeoff Minima are authorized in paragraph C057. The certificate holder is authorized to use
lower than standard takeoff minima in accordance with the limitations and provisions of this operations
specification as follows.
b. Runway Visual Range (RVR) Requirements. RVR reports, when available for a particular runway,
shall be used for all takeoff operations on that runway. All takeoff operations, based on RVR, must use
RVR reports from the locations along the runway as follows:
(1) For operations at or above RVR 1600 (500m):
(a) The TDZ RVR report, if available, is controlling.
(b) The mid RVR report may be substituted for an unavailable TDZ report.
(2) For operations below RVR 1600 (500m):
(a) A minimum of two operative RVR reporting systems are required.
(b) All available RVR reports are controlling.
NOTE: Extremely long runways (e.g., DEN 16R) utilize four RVR sensors: TDZ, mid, rollout, and
far-end. When a fourth far-end RVR value is reported, it is not controlling and is not to be used as one of
the two required operative RVR systems.
c. Lower Than Standard Takeoff Minima. When takeoff minima are equal to or less than the applicable
standard takeoff minima, and the operation is conducted in compliance with the provisions and limitations
of this operations specification, the certificate holder is authorized to use the lower than standard minima
described herein.
d. Touchdown zone (TDZ) RVR 1600 (beginning of takeoff roll) or visibility or Runway Visibility Value
(RVV) 1⁄4 statute mile, provided one of the following visual aids listed in d.(1) – (4) is available:
(1) High intensity runway lights (HIRL).
(2) Operative runway centerline (CL) lights.
(3) Serviceable runway centerline marking (RCLM).
(4) In circumstances when none of the above visual aids are available, visibility or RVV 1⁄4 statute mile
may still be used, provided other runway markings or runway lighting provide pilots with adequate visual
reference to continuously identify the takeoff surface and maintain directional control throughout the
takeoff roll.
e. The certificate holder is authorized to conduct operations using the lowest RVR authorized in Table 1
below based on the applicable criteria in this operations specification.
Table 1 – Lowest Authorized Takeoff RVR
Minimum Runway
Other Limitations and Provisions
Requirements
RVR 600 - TDZ / 600 - Mid / HIRL and CL Lights
N/A
600 - RO (175m)
NOTE: For operations below RVR 1600 (500m), a minimum of two operative RVR reporting systems are
required. All available RVR reports are controlling, except a far-end RVR report, which is advisory only.
f.
The certificate holder authorizations listed in Table 1 above are dependent upon the following criteria:
(1) TDZ RVR 1200 (350m) (beginning of takeoff roll), mid-RVR 1200 (350m) (if installed), and
rollout RVR 1000 (300m), if authorized, may be used provided RVR equipment and one of the following
visual aids combinations are available:
(a) Daylight Hours. HIRL or operative runway CL lights or serviceable RCLM.
(b) Night Time Hours. HIRL or operative runway CL lights.
(2) TDZ RVR 1000 (300m) (beginning of takeoff roll), mid-RVR 1000 (300m) (if installed), and
(a) Operative runway CL lights, OR
(b) HIRL and serviceable RCLM.
(3) TDZ RVR 600 (175m) (beginning of takeoff roll), mid-RVR 600 (175m) (if installed), and rollout
RVR 600 (175m), or TDZ RVR 500 (150m) (beginning of takeoff roll), mid-RVR 500 (150m) (if
installed), and rollout RVR 500 (150m), if authorized, may be used provided RVR equipment and ALL of
the following visual aids are available:
(a) HIRL.
(b) Operative runway CL lights.
g. Other Requirements. The certificate holder shall conduct all operations using the lower than standard
takeoff minima described in this operations specification in compliance with the following limitations:
(1) Each aircraft must be operated with a flightcrew consisting of at least two pilots. Use of an
autopilot (AP) in lieu of a required second in command (SIC) is not authorized.
(2) Each pilot station must have operational equipment which displays a reliable indication of the
following:
(a) Aircraft pitch and bank information, from a gyroscopic source.
(b) Aircraft heading, from a gyroscopic source.
(c) Vertical speed.
(d) Airspeed.
(e) Altitude.
(3) Each pilot station must have an independent source of power for the equipment required by
subparagraphs g(2)(a) and g(2)(b) above.
(4) Each pilot in command (PIC) must have at least 100 hours flight time as PIC in the specific make
and model airplane used under this authorization and must have satisfactorily completed the certificate
holder’s approved training program for the minima authorized by this operations specification, which
includes the methods to be used to ensure compliance with the performance limitations in
subparagraph g(6), when applicable.
(5) Any SIC authorized by the certificate holder to manipulate the flight controls during takeoff (using
the minima authorized by this operations specification) must have at least 100 hours flight time as a pilot in
the specific make and model airplane and must have satisfactorily completed the certificate holder’s
approved training program for those minima.
(6) For all takeoffs, each airplane must be operated at a takeoff weight which permits the airplane to
achieve the performance equivalent to the takeoff performance specified in 14 CFR § 135.367 for
reciprocating powered airplanes, § 135.379 for turbine powered airplanes, § 135.389 for large nontransport
category aircraft, § 135.397 for small transport category aircraft, or § 135.398 for commuter category
airplanes.
h. Approved Head Up Display (HUD) Takeoff Guidance Systems Minima. The certificate holder is
authorized to use the takeoff minima listed in Table 2 based upon the use of HUD system installed in
airplanes as listed in Table 2 below (RVR 300 (75m) is the lowest RVR minima that can be authorized
using a HUD) provided ALL of the following requirements are met:
(1) The certificate holder shall conduct no takeoffs using these takeoff minima apart from using the
HUD system.
(2) Special provisions and limitations for the authorization to use the HUD for takeoff:
(a) Operative HIRL.
(c) Front course guidance must be displayed from a localizer that provides CAT III rollout
guidance as indicated by a III/E/4 facility classification.
(d) The crosswind component on the takeoff runway is less than the airplane flight manual’s
crosswind limitation, or 15 knots, whichever is more restrictive.
(e) Operations using the minima in Table 2 below shall be conducted to runways that are
accessible by taxi routings which have operative taxiway CL lights that meets U.S. or ICAO criteria for
CAT III operations; or other taxiway guidance systems approved for these operations. This taxiway
guidance requirement is not applicable when operating in conditions that are at or above the certificate
holder’s approved takeoff minima as depicted in Table 1 above.
