WS
I'm hoping to get some insight on what YOU would do in this situation.
It's night, you have a very light load of freight, and the fog has rolled in earlier than anticipated. Everything points to it getting worse and lasting all night. You need 1800 RVR to take-off legally with freight on board. Since the visibility is well below part 135 takeoff minimums, your company wants you to leave the freight behind and blast off under part 91 rules to re-position for the morning departure on the other end.
The field is currently 1200 RVR with a 200' indefinite ceiling and is deteriorating rapidly, while you need 1800 RVR and 200' to get back in on the ILS. The nearest field that has any hope of being above landing minimums is at least 50 miles away, while 65 miles should get you to widespread stable VFR conditions.
Would you stay on the ground in a crappy hotel and put up with grief from your company, or would you depart?
Would it matter if you were flying a single or a twin, piston(s) or turbine(s)?
