Boots2Wings
Just happy to be here.
Why were they landing with a tailwind, on a short runway?
Surface winds are what count. Until enough people complain or GA
The problem is handflying of the magenta crowd, VNAV above 10k when the speed goes from 250 to ~280-290, and the level off at or below 11,000 ft.
Initially out of 10k and approaching 11k, the FD only shows a slight pitch down, which makes the pilot think brute doing okay. You have to pitch down into the FD and then it continues towards commanding a level off.
It’s a funky behavior that involves accelerating from 250 to 290kts, while also going through 10k but leveling 11k.
Not a big deal. Just pitch down to hold 11k and the plane will do just that. But again, you have magenta line pilots and they bust right through.
Initially out of 10k and approaching 11k, the FD only shows a slight pitch down, which makes the pilot think they’re doing okay. You have to pitch down into the FD and then it continues towards commanding a level off.
NYWhy were they landing with a tailwind, on a short runway?
Runways sit on piers on the bay.Question from this noob - why won't they allow the use of AP on this approach?
As a tower controller I never considered the winds aloft until I got to a tower that lost its tracon. We had the winds aloft display there and often used it to make configuration choices.NY
Also famous for massive tailwind on approach but calm or completely opposite at the surface is DEN. that combined with the fact the FAF is only 1200AFE on 2 runways. It’s really easy to get dorked up there.
It's common to land with a small headwind/tailwind when winds aloft (500AGL) are strong 30-60 KTS on the tail, it's very hard to get slow and configured and even more to be stabilized. If they were to land the other direction, (headwind on approach) it's easier to configure and be stabilized but most likely the loss in headwinds will result in a wind shear event and a GA. I see it DEN the most.Why were they landing with a tailwind, on a short runway?
Following the magenta FD or even magenta lines only, without actually doing a crosscheck of other instrument data, will bite you in the butt.
I was a fairly seasoned Airbus guy and got "yelled" at for calling for FDs off in the 737 sim once out of habit when things got wonky. Not sure of the logic, but it's a pretty routine thing for me to kick them off in the bus on a visual.However, in the Airbus, it’s follow the FD pitch bars or turn them off. The autothrust assumes you’re at least following the pitch commands.
(Asterisk asterisk asterisk!)
Back in the day when I started at USAir, RNAV SIDs had to have the autopilot engaged at the lowest usable altitude. Too many people were almost flying into each other in CLT (back when they had true RNAV SIDs). Hand flying was not allowed.A handflown RNAV departure procedure is a ‘maneuver’ now and has been for almost a decade because people screwed it up.
Two years in the left seat I’ve had exactly zero FOs do a visual with the FD off. It’s so weird because they loooove to hand fly on departures up to 10k+. Not sure what skill that takes. All you’re doing is following the FD and modulating pitch. Hardly “hand flying”.
While on the Bus we turned the FDs off all the time.
I’m not surprised, the lack of spacial awareness, configuration, etc is kinda shocking. You have to “think in 3D” with this job and all you need to know is your distance, speed, and alt to the runway. It’s not that hard.I’ve pretty much stopped issuing visual approaches to 121 because y’all don’t turn towards the airport anymore. Instead yall (generic yall) square off base to final and wind up flying 2-3 miles more than if I had just vectored for the ILS.
