ChasenSFO
hen teaser
This. Don't feed these leeches.Yup. Don’t respond to anyone on here that you’re not familiar with and even when you do, keep the speculation to a minimum
Looks like under 200. Still cant put those two aircraft in that same realestate.For those saying military helicopter route 4, what is the helicopter altitude restrictions for this route 4?
This is a Falcon replay. Kind of amazed it got out this quick. Also zoomed in and cropped a lot. The tower controller most likely wouldn’t have been looking at this as they’d be looking out the window.
The data is coming from the same antenna, depends on the tower and set up if the tower has their own system or not. I've worked at towers that have had it both waysdo the towers have their own radar, or are towers inside Class B/C looking at a TRACON feed?
Obvious too soon to speculate on causes, but it will be interesting to see if there's a push to move more traffic to IADHot take: With the silver line opening to Dulles a few years ago, maybe it's time we close Reagan?
Doing VFR in slow movers its a lot easier to keep stuff in sight as I don't have to look down much at all, and as I'm usually not looking against lights at the other traffic as its above me, so I'm happy take over the visual separation for ATC...but I'll also pester them right away if I somehow lose sight of that airplane after maneuvering so I'm quick to pass it back to them if needed. Especially if that traffic probably isn't looking out for me at all.I hate hate hate being asked to call traffic in sight when there are a number of airplanes at night. I don’t know a Cessna from Boeing in the dark.
Exactly. DCA isn't going anywhere. The DCA traffic has to start/end at the runways, the other stuff in the airspace will need revision I'd imagine.If 9-11 didnt shut down DCA forever I cant see how this could/should.
The path you see depicted from the RJ is exactly SOP. There is not way the helicopter should have been cleared along that route with someone landing 33. Helicopter was at 300 give or take when they hit I believe. Having low level helicopters fly below you as you climb well above is SOP there. But in no scenario would you be put where you are passing within 100' of one.I’m having a hard time understanding that route can be approved with circling approaches to a runway that obviously presents a conflict. Only landed 19 the few times I’ve gone into DCA, but would be curious to know what the altitude is lining up for 33 over the river. I don’t want to armchair QB it, but if the helo was below 200 and still clipped the plane, that route should be a no go with ops into 33 from here on out imho. Even seems like a potential wake turbulence issue if you’re threading in between airplanes that are landing.
I feel for all those involved, my gut is wrenched tonight.
Those poor people. That is one hell of a wreck.
