Achoo (91.113) snifff snifff,
Did someone let a cat in?
Not sure how you could apply this to your situation.
91.113, Right of way rules
(a)
Inapplicability. This section does not apply to the operation of an aircraft on water.
Self explanitory
(b)
General. When weather conditions permit, regardless of whether an operation is conducted under instrument flight rules or visual flight rules, vigilance shall be maintained by each person operating an aircraft so as to see and avoid other aircraft. When a rule of this section gives another aircraft the right-of-way, the pilot shall give way to that aircraft and may not pass over, under, or ahead of it unless well clear.
Self explanitory, we see you(most of us) so we avoid you.
(c)
In distress. An aircraft in distress has the right-of-way over all other air traffic.
Are you declaring an emergency??? Because if you are, RELEASE THE DAMN BANNER!!!!!
(d)
Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories—
This depends on who is on the right.
(1) A balloon has the right-of-way over any other category of aircraft;
Are you towing the banner w/a ballon?
(2) A glider has the right-of-way over an airship, powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.
Or are you using the GoodYear blump. Doesn't it have a lighted sign. Why do you need a banner then?
(3) An airship has the right-of-way over a powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.
However, an aircraft towing or refueling other aircraft has the right-of-way over all other engine-driven aircraft.
Is that rope attached to another sirplane that's towing the banner?
(e)
Approaching head-on. When aircraft are approaching each other head-on, or nearly so, each pilot of each aircraft shall alter course to the right.
O.K. You win on this one, we'll pass on the right
(f)
Overtaking. Each aircraft that is being overtaken has the right-of-way and each pilot of an overtaking aircraft shall alter course to the right to pass well clear.
If your towing that banner with a beer picture on it (mmmmmmm:drool
, you certainly are not landing. You need to drop your banner 1st.
(g)
Landing. Aircraft, while on final approach to land or while landing, have the right-of-way over other aircraft in flight or operating on the surface, except that they shall not take advantage of this rule to force an aircraft off the runway surface which has already landed and is attempting to make way for an aircraft on final approach. When two or more aircraft are approaching an airport for the purpose of landing, the aircraft at the lower altitude has the right-of-way, but it shall not take advantage of this rule to cut in front of another which is on final approach to land or to overtake that aircraft.
Did I miss anything?
