He’s just venting. If anything, AS is a heavily FO centric airline. As you already mentioned, the seat belt sign is a good example. At VX, we’d never touch that switch unless discussing with the CA first, like hey, whatcha think of the seat belt sign, little rough here? At AS, I’ve had times I hit the slightest of ruffles and the guy in the right seat just reaches up and throws the sign on. No discussion, no comments. FOs also almost exclusively do the walkaround and program the box. One time, I had a FO complain I did the box, and this is when HE showed up 25 minutes before departure. I’d already done my job/setup, then did the walkaround, then when he still wasn’t here, I did the box. And he apparently took offense I had helped set anything up. I’m a nice guy, so I let it go. Didn’t wanna get off in the wrong foot. I just said I didn’t see anyone here, thought it was a rsv callout and decided to help. But damn dude, show up late and have attitude, first time meeting for the first leg.
At VX, CAs would routinely do walkarounds or program the box if FO was walking around. AS, it’s pretty much FOs and when I transitioned, they made it a point that FOs at AS 737s do walkarounds and the FMC.
While we are beotching, what is it with the lack of consistency on the GPWS test on the ground? I’ve reached a point now where I will call them out and tell them to do it the right way. Offender #1…. They throw on both ACPs switch from NORM to ALT and run the GPWS test, so we hear nothing and it’s quiet. Um, the whole point is to hear the warnings! Offender #2… double punching the test switch to get the second level test, the “no faults” aural. 737 stand notes says double punching is a maintenance function and not considered a valid EGPWS test. If I see either of these two offenses, I politely ask to have it be re-run the proper way.
