What is the crew composition ? Were they legacy hires, 121 only, military, or (gasp) any 91/135 experience ? How about checkride failures?
These are the important questions we need to be asking.
Boeing wants FAA to exempt MAX 7 from safety rules to get it in the air
Jan. 5, 2024 at 6:00 am
Since August, earlier models of the MAX currently flying passengers in the U.S. have had to limit use of the jet’s engine anti-ice system after Boeing discovered a defect in the system with potentially catastrophic consequences.
The flaw could cause the inlet at the front end of the pod surrounding the engine — known as a nacelle — to break and fall off.
In an August Airworthiness Directive, the FAA stated that debris from such a breakup could penetrate the fuselage, putting passengers seated at windows behind the wings in danger, and could damage the wing or tail of the plane, “which could result in loss of control of the airplane.”
Dennis Tajer, a spokesperson for the Allied Pilots Association, the union representing 15,000 American Airlines pilots, said the flaw in the engine anti-ice system has “given us great concern.”
He said the pilot procedure the FAA approved as an interim solution — urging pilots to make sure to turn off the system when icing conditions dissipate to avoid overheating that within five minutes could seriously damage the structure of the nacelle — is inadequate given the serious potential danger.
“You get our attention when you say people might get killed,” Tajer said. “We’re not interested in seeing exemptions and accommodations that depend on human memory. … There’s just got to be a better way.”
In its petition to the FAA, Boeing argues the breakup of the engine nacelle is “extremely improbable” and that an exemption will not reduce safety.
Yes, more seats=more exits.Oh like they need more exits if there are more seats crammed in? Or do you mean they plugged them to allow higher density seating?
"Oooooh, sorry Alaska, you didn't opt for the extended warranty. There's nothing we can do after 30 days. We can give you a $650 credit towards a 737-1000000000XXXXXXXL, which should be certified in 2063."
Nice job getting back to an airport.Well Boeing tried calling some folks, but the cellphones were all sucked out of the open plug.
in reality, job well done by the crew to get it back on the deck.
Can you use ID90 Travel yet?Well that’s gonna screw things up. My fam non reved to MN for a funeral, gonna guess it might be a bit before they can get back
Nope I think that kicks in at 6 monthsCan you use ID90 Travel yet?
I hear the Empire Builder is an absolutely delightful way to travel.Well that’s gonna screw things up. My fam non reved to MN for a funeral, gonna guess it might be a bit before they can get back
Does that "door" still show up on the doors page ? So would the crew see door open in this case?“Supposed to be bolted shut, and not accessible…covered by standard interior wall panelling. Doesn’t look like Boeing fully secured it” - from a friend who’s husband is an AS MX supervisor
Not sure if you're joking or not......Does a 737 have any "page?" Or just recall lights?Does that "door" still show up on the doors page ? So would the crew see door open in this case?
