Vis a vis "it's in the manuals"...eh, are you sure?
I could never find anything on just what "flare assist" does on the 747-8. There are five mentions that I can find.
1) The QRH lets you know that with the "FLARE ASSIST" EICAS message, "higher than normal column forces may be required during flare. Use flaps 25 and VREF 25 for landing." and "Select the FLARE ASSIST non-normal when requesting landing performance"...then? CHECKLIST COMPLETE.
2) The AOM gives you performance tables for landing flaps 25 with the "flare assist" EICAS message, presumably in case the ACARS performance isn't working for whatever reason.
3) The FRM gives you a fault code, naturally
4) The Systems Manual....THE SYSTEMS MANUAL just gives you the EICAS message, the alert level, that there is an aural warning, and the "message logic" which is "Landing flare assist is inoperative". That's it. It broke. We no know why broke. Land plane, get banana.
5) The most useful of all? It's in the MEL! Where else would it be??? It helpfully informs you that with the FLARE ASSIST Caution "Flare compensation is inoperative due to failure conditions". It doesn't work because it's broken! Thank you, that's helpful! "Flare compensation is provided by elevator flare pitch augmentation" So it compensates by...compensating? "NOTE: Spoiler direct lift control is no longer used" Spoiler...spoiler DIRECT LIFT CON...WHAT THE HELL IS THAT?
The answer is of course that this seems to be the only mention of "spoiler direct lift control" in anything I have access to. What is it? It controls lift, I guess. How does it work? Shut up and press the buttons.
Anyway, point being, I would not just casually assume that *anything* is "in the manuals if you dig enough". *shrug*
