I was referring to when you were still carrying power. Gear down midfield, keep your speed up until abeam the touchdown point, then chop power. The faster you are at that point, the more airspeed you have to convert into altitude.
Easy. Since you seem technically minded, draw the induced drag curve and parasite drag curve. The speed of best glide is at the intersection. Now raise the parasite drag curve due to gear extension and see what happens to the best glide airspeed.
First, thanks for clearing that 120 up that was as shocking to me as the intern_mike with the 60 degrees transition to slip. You had me seriously scared sir!
As for the second thanks thats what I was thinking but was unsure if thats where you were going with that. Still no book value so I wonder how much it really is effected but the gear is 500 feet per minute so I would assume your right that it is pretty substancial. I will have to play around with that some next time I am in an Arrow. Thank you sir.
