Thank you Jrsyguy us Jersey folk must stick together!!!
To restate yet again I never said these maneuvers shouldn't be known and you shouldn't be able to use them. I said with proper planning you shouldn't have to especially in an emergency when there are many other factors involved.
As for all this turn arguments time to settle this once and for all math doesn't lie.
For the arrow 79 knots
Radius - 961 feet
Diameter - 0.3 nautical miles
180 degree turn time - 22.6 seconds
If your telling me that you fall 1000 feet in 22.6 seconds man I would love to know who maintains your aircraft!
Now for the folks about to say oooo what about wind here are some numbers for higher speeds:
For 100 knots:
Radius - 1540.8 feet
Diameter - 0.5 NM
180 degree turn time - 28.6 sec
For 120 knots:
Radius - 2218.1 feet
Diameter - 0.7 NM
180 degree turn time - 34.4 sec
For 140 knots:
Radius - 3020.0 feet
Diameter - 1 NM
180 degree turn time - 40.1 sec
For 200 knots:
Radius - 6163.3 feet
Diameter - 2 NM
180 degree turn time - 57.2 sec
All of this can be found at
http://www.csgnetwork.com/aircraftturninfocalc.html
Look at the time for your 180 degree turns at 30 degrees even for 200 knots as long as your best glide yields less then 1000 feet per minute you can easily perform the turn to land safely as long as you judge your diameter properly. Sure some higher performance aircrafts will be over 1000 feet a minute especially twins with dual engine outs. But the arrow is right at 1000 feet a minute at best glide and it is a horrible gliding aircraft.
Let me repeat so I don't get bashed here, these are not absolutes they don't' take into account lift and sink. However, they do show that for any plane 140 knots or less best glide you will have approximately 20 seconds to spare after doing a 30 degree bank 180 degree turn if altitude loss is at or below 1000 feet a minute at glide.
Sorry for all the math got tired of this arbitrary number BS going on.
