z987k
http://www.risingup.com/planespecs/info/airplane372.shtml
I think in Denver things would be spooky - especially with an old plane, and with the Vg kit, I think SE Service Ceiling would be below ground in Denver (I'll check the STC next time I think about it) but theoretically, you should be able to climb out a little bit. Anecdotal evidence suggests that it is possible to survive a V1 cut in the thing, I met a guy in Nome a few years ago who told me that he lost one about a second after rotation in Fairbanks in the summer (read 80 degrees or so) and he said he was sinking rapidly with the gear and flaps out, with the gear and flaps up he was sinking at 50 fpm, and with the dead cowl closed and the good one open he was climbing at about 150fpm - yes he said the cowls made that much of a difference. So... I dunno, he also had the high gross weight kit on and was "loaded up" in his words.
My opinion? Takeoff with max power in all twins (and pistons for that matter) unless you have performance and the performance data available to take of with less - it lessons the steps you have to take after takeoff to get max power out of the engine. In the Navajo, if you lose an engine after you've already selected the gear up or are in the process of it, and catastrophically lose an engine there, let's say at the "barrier speed," then you're looking at having to go back over to the throttles and push the power the rest of the way up before going over to the flaps to retract them (if you use them) or starting the feathering process, because you're gonna need all the power you can get.
As for landing with the props back at 2300RPM, well, here they want us to have the props at 2400RPM for landing, I do, but I go a step further, once I get off of the governors (at about 90 - 85 KIAS) then I reach and push the props the rest of the way up to get max power if I need it in case a fourwheeler or a truck drives on the runway or whatever.
Ya, that's what I did. Once off the governor, props full. The reason they did it I think was noise abatement, and at that point we're still getting the same result, but being smart and safe about it. That 13k ceiling on one engine is BS, not even close in any I flew. On one of my checkrides we did the SE approaches into LMT, and it was everything it had to keep on the glideslope, we ended up circling at higher than MDA and sinking down to it on the circle in time to turn base and descend from MDA. This was empty.
