CoffeeIcePapers
Well-Hung Member
Okay...... so you just contradicted the post that said that no POH is required - because an AFM is essentially a POH.....
The bottom quote is 21.5. Not every aircraft needs the AFM or POH.
Inspired by a question in another thread.
What are some common misconceptions you have run into while working as a CFI.
It's ignorance, not necessarily stupidity. Some people think that flying is an incredible difficult think to do and are surprised that someone can actually go up by themselves after only a dozen or so lessons. Others, probably like this lady, may think just the opposite, that a quick lesson and off you go. Maybe she's had experience renting a motor boat.Nice, even with all the information available, people are still stupid.
You must turn your cell phone off before flying.
A CAR 3 airplane doesn't need a POH, an AFM, a shoulder harness, an approved checklist, or placards in the cockpit.
It's an example of another misconception: The FAR are the only rules and regulations that are involved in flying.What about this FCC Regulation, 47 CFR 22.925?'
Life would be easier if there were only one set of rules, all from the same source, but it tends not to work that way.It sure as heck would be easier if they were.
Here is a fun one that spread around our school like wild fire not that long ago.
A 141 Stage Check does indeed reset the 24 cal month flight review clock.
Oh it doesn't? Well that is considered norm at the school that I went to.
http://forums.jetcareers.com/cfi-corner/78922-biennial-flight-review.html
we are talking about this is a separate thread.
Sec. 22.925 Prohibition on airborne operation of cellular telephones.
Cellular telephones installed in or carried aboard airplanes,
balloons or any other type of aircraft must not be operated while such
aircraft are airborne (not touching the ground). When any aircraft
leaves the ground, all cellular telephones on board that aircraft must
be turned off. The following notice must be posted on or near each
cellular telephone installed in any aircraft:
``The use of cellular telephones while this aircraft is airborne is
prohibited by FCC rules, and the violation of this rule could result in
suspension of service and/or a fine. The use of cellular telephones
while this aircraft is on the ground is subject to FAA regulations.''
