R
Roger, Roger
Guest
Something I regularly lived by in fighters for years.
I seem to remember you saying the 117 really, really liked it's speed.
This rule (250 below 10,000) came about because of TWA 553 in 1967. TWA553 was a DC-9 that collided with a Baron in Urbana, Ohio. ATC cleared TWA to descend from the 20's to 3,000 going into Dayton and they collided with a Baron at 4,500 or so. The Baron was not talking to ATC and the DC-9 was going real fast and slammed into it - no time to see and avoid. My Grandpa flew the initial acceptance flights for the DC-9 and created the training for the airplane. By 1967 he was running the training department at TWA and was kind of the "expert" on the airplane. He was part of the accident investigation and that crash led to the 250 under 10k rule as well as led to TCA's. He had a huge box full of papers and his notes from the investigation, plus they gave him a personal copy of all the documents and reports (I think because he had to testify so he got a copy separate from TWA). Anyway, that was fascinating reading - really amazed me the volume of work that there was.
Actually, 250 below 10K came out 7 years prior to the accident you cite. The 250 below 10k rule was the result of the December 1960 midair collision between UAL 826 (DC-8) / TWA 266 (L-1049) over New York City. The UAL jet was in excess of 500 kts when it overshot it's holding fix by a good number of miles.
I am probably mis-remembering. I was under the impression that afterr the NYC collision they changed the rules but it was something like 250, under 14,000 or so, within 50 NM of the airport, and only for arriving aircraft. I thought that was the initial rule, then after Urbana it was just a blanket "under 10,000). I'll have to look that up. As I said, I'm probably mis-remembering things!
Seagull, I do know we don't do that much. I think it's usually around the upper 270s. That MD-11 likes it's speed, eh?
Naw, you're probably right on the blanket rule. The rule started as 250 below 10 within 30nm of the airport. Subsequently made blanket, probably after the accident you cite; but the original ruling with the restriction came from NYC. Additionally, rules like reporting equipment malfunctions to ATC, slowing to hold speed 3 mins prior to the hold fix, and requring all turbojet and aircraft over 12.5K to have DME, came from this accident.
IDK, never flown a 76. We have a bank limit at V2+80 (which is clean) then normal maneuvering at V2+100, which is what we climb at below 10k. Occasionally, we'll hold the flaps if we're in a speed restricted segment in a turn, then clean up as we get the 15 degrees of bank limit).
Lots of tight slow turns on some of the departures in Europe so we'll just leave the flaps out and accelerate later. But generally speaking, there are quite a few airports where you do the, what is it, the NADP1 (or is it 2?) where your acceleration height is 3000 AFE so you're pretty slow anyway.
I've only flown 6 legs in the beast but, yeah, NADP 1 is your 3000 ft acceleration 1500 ft thrust reduction departure. Of course, my check captain preferred to do NADP-1 max flaps all the time, even domestic :dunno: . I think he was paranoid about noise sensors.
NADP1 is in the book as the "standard" departure profile at our company, but we almost always do NADP2 (1000' AFE accel) unless it's specifically required. I think we'd be getting yelled at for being a speedbump out of the major hubs like DFW if we did NADP1 all the time. We're already a speedbump at ECON descent speed, anyway.
Anyway, for the original question: Yeah, I accelerate if we're level at 10,000. To quote my XJT IOE captain: "This is a jet. Jets go fast!"![]()
Hah, I wish I could say I haven't had an F-bomb dropped on me for not inputting .833/290 instead of econ descent into VNAV after my arrival briefing! You guys actually do the econ descents?
Maybe someone can answer this question for me without me looking it up. Coming back from the HOU area into ADS at around 15000 descending center asked our speed and I said 290K, they then cleared me to 8000 and said maintain speed. Later we were handed over to approach and at the same time center said normal speed.
In the US if ATC tells you to go over 250K below 10000 is it legal to do so?
There was a sort of flow-expedite program going in some terminal airspace areas where they were allowing aircraft to exceed 250 below 10k. Don't know if HOU was one of them, but I believe it might have been.
