bidderswede
61.51. If you are rated for the aircraft and are the sole manipulator of the controls, you may log that as PIC. It says nothing about endorsements. Endorsements are not ratings.
FAR 61.51
(e) Logging pilot-in-command flight time. (1) A recreational, private, or commercial pilot may log pilot-in- command time only for that flight time during which that person --
(i) Is the sole manipulator of the controls of an aircraft for which the pilot is rated;
(ii) Is the sole occupant of the aircraft; or (iii) Except for a recreational pilot, is acting as pilot in command of an aircraft on which more than one pilot is required under the type certification of the aircraft or the regulations under which the flight is conducted.
Yes he's "rated" to fly Multi Engine aircraft as PIC, but there is an extra requirement for a pressurized aircraft with a service ceiling above 25,000'. Which is the High Alt endorsement.
The type certification for a BE-20, (King Air 200) doesn't require more than one pilot, neither does the regulations under which the flight is conducted.
He was going to log PIC on "empty legs", which means the flight will be conducted under Part 91.
