BobDDuck
Island Bus Driver
What I was really trying to ask is are there better ways in which to brief the threat of landing at the wrong airport well before you start looking out the window for it in the terminal area? For example, I think almost all the airports in Europe have some sort of charted visual flight procedure regardless of their size, like this one for Innsbruck (I always thought these were overkill FWIW).
Would something like that, or even just a sectional/TAC excerpt of the destination airport area, improve situational awareness? So that when heads do go outside and the PF is flying reference to the airspeed indicator only, they have a better idea of what to expect (like seeing the wrong airport before they see the right one)? Or are the existing company-specific 10-7 pages enough to warn pilots what to watch out for?
For airports that a company regularly operates in to, Tribal Knowledge is probably the best defense against this. I'd always brief an FO, going in to places like BWI that it was going to be the SECOND runway we saw that we were landing on and such. Hopefully that use that when they brief in the future. Same deal for which airport we'd be planning to land at. I think Columbia, SC is a good example of that. The downtown airport beacon (especially at night) can very easily be confused with Metro (or wherever they are calling it now). Coming in from Charlotte the runways weren't aligned in a way that would be confusing, but if you were arriving from the east, it would certainly be a briefing item of importance.
That said, if you are operating in to an airport neither pilot has ever been before, having something like a sectional may be helpful to get a sense of the geographic area. A 10-9 page shows nothing more than the runway diagram and doesn't give any insight into nearby hazards like mountains and towers, or any geographic locational help like where the airport is in relation to metro areas, rivers, lakes and (what's important to this discussion) other airports. Even an approach plate (if you are backing up your visual with a charted instrument procedure won't show much more than high terrain. Every once in a while you will get a secondary airport charted and note not to confuse it with where you are going (MGM comes to mind here) but that isn't common.
The best thing of course is to do a very thorough brief and then fly the approach (visual or instrument) that you've briefed. Also, while I certainly won't say I could never do something like that (land at the wrong airport), with a moving map display, it should be VERY difficult mistake to make. Most systems zoom in to 5 miles which should certainly provide enough fidelity to show that you are 500 feet off the ground and nowhere near the airport you are supposed to be going to. That said, I've seen a lot of guys never scroll in their map displays from cruise so they are landing at an 80 mile range, where it is impossible to see anything in the terminal area.
